Acer R231bmid 23" 1920x1080 4ms VGA DVI HDMI Monitor
Quicklinx: CP8BWS00 Mfr#: UM.VR1EE.001
Select:
  • 23"
  • Slim and trim
    R1 displays have an ultra-thin enclosure with most of the display being only 6.6 mm thick, thinner than many smartphones. In addition, the"ZeroFrame" design maximises the view and minimises visual clutter with a bezel so thin that you barely notice it.
  • On display
    You get a great view with our R1 displays. You get 1920 x 1080 Full HD resolution enhanced by IPS technology that produces vivid colours and a wide 178 viewing angle. You also get multiple display connectors to make it easy to connect.
  • A comfortable view
    Our R1 displays are designed to help preserve eye health. Flicker-less design reduces eye strain from screen flicker. A Blue Light Filter reduces the negative effects of excess blue spectrum exposure, and our ComfyView reduces screen reflection.
Acer R231 - LED monitor - Full HD (1080p) - 23"
LED-backlit LCD monitor - 23"
Energy Class
Class D
Energy Consumption per Year
33 kWh
Power Consumption (On mode)
13.2 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
72% NTSC
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
AC 100/240 V
53.1 cm x 22.38 cm x 40.2 cm
Environmental Standards
ENERGY STAR Qualified
MPR II
Display Type
Energy Class
Class D
33 kWh
Diagonal Size
23"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72% NTSC
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Acer EcoDisplay, ComfyView, Zero Frame, Flicker-Less technology, Blue Light Filter technology, 72% NTSC colour gamut
53.1 cm x 22.38 cm x 40.2 cm - with stand
Audio
Speakers - stereo
Output Power / Channel
2 Watt
VGA , DVI (HDCP) , HDMI , Audio line-out
Mechanical
Tilt
Tilt Angle
-5/+15
1 x VGA cable
MPR II
Input Voltage
AC 100/240 V
13.2 W
13.2 kWh/1000h
Power Consumption (Typical)
30 Watt
Power Consumption Stand by
450 mW
Power Consumption Sleep
400 mW
Dimensions & Weight Details
Without stand - width: 53.1 cm - depth: 3.34 cm - height: 31.97 cm , With stand - width: 53.1 cm - depth: 22.38 cm - height: 40.2 cm
Sustainability Information
ENERGY STAR Certified
