Acer ProDesigner BM320 32" 3840x2160 6ms DVI HDMI DP USB Monitor
Quicklinx: CP8RWS00 Mfr#: UM.JB6EE.009
Acer BM320 - LED monitor - 32"
LED-backlit LCD monitor - 32"
Energy Class
Class B
Energy Consumption per Year
70 kWh
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K UHD (2160p) 3840 x 2160 at 60 Hz
Brightness
350 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
6 ms
Colour Support
1.07 billion colours
Colour Gamut
100% Adobe RGB
Input Connectors
HDMI, DVI-D, DisplayPort, Mini DisplayPort
Display Position Adjustments
Matte black
72.75 cm x 20.08 cm x 61.58 cm
3-year warranty
Display Type
Energy Class
Class B
70 kWh
Diagonal Size
32"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
100% Adobe RGB
Response Time
6 ms
Horizontal Viewing Angle
178
Backlight Technology
LED backlight
Zero Frame, Flicker-Less technology, Acer VisionCare, Acer BluelightShield technology
Matte black
72.75 cm x 20.08 cm x 61.58 cm - with stand
Audio
Speakers
HDMI , DVI , DisplayPort , Mini DisplayPort , USB 3.0 upstream , 4 x USB 3.0 downstream , Audio line-in/out
Mechanical
Tilt Angle
-5/+25
Swivel Angle
45
Rotation Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Acer ColorPlus technology
Dimensions & Weight Details
With stand - width: 72.75 cm - depth: 20.08 cm - height: 61.58 cm , Without stand - width: 72.75 cm - depth: 5.89 cm - height: 43.1 cm
Limited warranty - 3 years
