The world's first curved gaming monitor that completely immerses you in the game universe. Absolutely stunning.
Curved immersion
Get immersed in the world's greatest curved gaming display. Your gaming experience will never be the same again. -
Super-smooth
Get the buttery-smooth gameplay you've dreamed of. NVIDIA G-SYNC eliminates screen tearing and minimises stuttering for legendary PC gaming. -
Become a hunter
Conquer your enemies with Predator GameView. Shooting aim-points and customizable gaming profiles give you the upper hand. -
Overclock
Boost your refresh rate up to 100Hz with built-in overclocking. Minimise motion blur and enjoy more frames per second.
- Acer Predator Z321Q - LED monitor - curved - Full HD (1080p) - 31.5"
- LED-backlit LCD monitor - 31.5"
- Energy Class
- Class A
- Energy Consumption per Year
- 58 kWh
- Curved Screen
- Adaptive-Sync Technology
- NVIDIA G-SYNC
- USB 3.0 hub
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 144 Hz
- Brightness
- 300 cd/m²
- Contrast Ratio
- 3000:1 / 100000000:1 (dynamic)
- Response Time
- 4 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72%
- Input Connectors
- HDMI, DisplayPort
- Height, swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 72.2 cm x 29.99 cm x 45.75 cm
- 10.6 kg
- Environmental Standards
- ENERGY STAR Qualified
- MPR II
- 2-year warranty
- Display Type
- Energy Class
- Class A
- 58 kWh
- Diagonal Size
- 31.5"
- Curved Screen
- Yes (1800R)
- NVIDIA G-SYNC
- Built-in Devices
- USB 3.0 hub
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72%
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Ambient light sensor, Acer EcoDisplay, Flicker-Less technology, DTS Sound, 8-bit gamma, Wide Viewing Angle, Acer BluelightShield technology
- Black
- 10.6 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 7 Watt
- DisplayPort , HDMI , USB 3.0 upstream (Type B) , 4 x USB 3.0 downstream (Type A) , Audio line-out (mini-jack)
Mechanical
- Tilt Angle
- -5/+25
- Swivel Angle
- 50
- Height Adjustment
- 120 mm
- VESA Mounting Interface
- 100 x 100 mm
- Included Accessories
- Stand
- Cables Included
- 1 x SuperSpeed USB cable , 1 x DisplayPort cable
- MPR II
- Input Voltage
- Power Consumption (Typical)
- 35 Watt
- Power Consumption Sleep
- 0.5 Watt
- 0.45 Watt
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 2 years - carry-in
