Acer Predator X34A 34" 3440x1440 4ms HDMI DVI USB Gaming Monitor
Quicklinx: CPB6WS00 Mfr#: UM.CX0EE.A01
The 34-inch curved 21:9 ultra-wide Predator X34 monitor (formally known as the XR341CKA) is a curved monitor with NVIDIA G-SYNC, providing an immersive gaming experience with minimal stutters and screen tears. It features DTS sound, 2x7W speakers, a zero-frame design with a futuristic aluminum base and ambient lighting options create an exciting entertainment experience with style. The Predator X34's UltraWide QHD (3440 x 1440) IPS panel has a 178-degree viewing angle, and also features flicker-less technology to lessen eye fatigue for a more comfortable gaming or working experience.
  • Curved immersion
    Get immersed in the world's greatest curved gaming display. Your gaming experience will never be the same again.
  • Super-smooth
    Get the buttery-smooth gameplay you've dreamed of. NVIDIA G-SYNC eliminates screen tearing and minimises stuttering for legendary PC gaming.
  • Become a hunter
    Conquer your enemies with Predator GameView. Shooting aim-points and customizable gaming profiles give you the upper hand.
  • Overclock
    Boost your refresh rate up to 100Hz with built-in overclocking. Minimise motion blur and enjoy more frames per second.
Acer Predator X34A - LED monitor - curved - 34"
LED-backlit LCD monitor - 34"
Energy Class
Class C
Energy Consumption per Year
93 kWh
Power Consumption (On mode)
64 W
Curved Screen
Adaptive-Sync Technology
NVIDIA G-SYNC, VESA Adaptive-Sync
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
21:9
Native Resolution
3440 x 1440 at 100 Hz
Brightness
300 cd/m²
Contrast Ratio
1000000:1 / 100000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
1.07 billion colours
Colour Gamut
100% sRGB
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Height, tilt
Screen Coating
Anti-glare
Voltage
82.5 cm x 30.9 cm x 45.6 cm
9.95 kg
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, MPR II, UL, TUV GS, VCCI, cUL, NOM, CCC, RoHS, ISO 9241-307, WEEE, cTUVus, EAC, NOM-1-NYCE
Display Type
Energy Class
Class C
93 kWh
Diagonal Size
34"
Curved Screen
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
21:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
100% sRGB
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
172
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Picture in picture, ambient light sensor, picture by picture, Acer Adaptive Contrast Management (ACM), High Frame Rate Control (Hi-FRC), ultra wide viewing angle, Zero Frame, Flicker-Less technology, 6-axis colour adjustment, Blue Light Filter technology, DTS Sound, 8-bit gamma, Predator GameView technology
82.5 cm x 30.9 cm x 45.6 cm - with stand
9.95 kg
Audio
Speakers - stereo
Output Power / Channel
7 Watt
DisplayPort , HDMI , USB 3.0 upstream , 4 x USB 3.0 downstream
Mechanical
Height, tilt
Tilt Angle
-5/+35
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
VESA interface support, Acer Eyeprotect technology, Acer ColorPlus technology
Stand
1 x HDMI cable , 1 x DisplayPort cable , 1 x SuperSpeed USB cable
Input Voltage
64 W
Power Consumption (Typical)
54 Watt
Power Consumption Sleep
500 mW
Power Consumption (Off Mode)
400 mW
Dimensions & Weight Details
With stand - width: 82.5 cm - depth: 30.9 cm - height: 45.6 cm - weight: 9.95 kg , Without stand - width: 82.5 cm - depth: 30.9 cm - height: 45.6 cm - weight: 7.39 kg
Sustainability Information
ENERGY STAR Certified
