- Acer P8800 - DLP projector
- DLP projector - 4K
- Brightness
- 5000 ANSI lumens
- Contrast Ratio
- 1200000:1 (dynamic)
- Resolution
- 3840 x 2160
- Native Aspect Ratio
- 16:9
- Colour Support
- 1.07 billion colours
- Lens Shift Direction
- Horizontal, vertical
- Bulb type
- UHP 465 Watt
- Bulb life cycle
- Up to 2000 hour(s) - normal mode , Up to 3000 hour(s) - economic mode
- Video Input
- RGB
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p, 2160p
- Power
- AC 120/230 V
- 585 Watt
- 55 cm x 50 cm x 19.2 cm
- 16.5 kg
Projector
- Brightness
- 5000 ANSI lumens
- Brightness (Reduced)
- 4000 ANSI lumens
- Contrast Ratio
- Image Size
- 170 cm - 762 cm
- Projection Distance
- 2.5 m - 8.9 m
- Throw Ratio
- 1.35 - 2.63:1
- Uniformity
- 85 %
- Digital Zoom Factor
- 1.25x
- Resolution
- Ultra HD 4K - 3840 x 2160
- 16:9
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 135 kHz
- Bulb type
- UHP 465 Watt
- Bulb life cycle
- sRGB colour profile, BrilliantColor, ColorBoost II+ Technology, SmartFormat Technology, EcoProjection Technology, 4:3 aspect ratio support, Auto Power Off, Acer ColorSafe II Technology, Rec. 709 Mode, Quick-Start, High Dynamic Range (HDR), XPR technology, Acer AcuMotion, Rec. 2020 Mode
Lens
- Focus Type
- Manual
- Lens Aperture
- F/1.7 -2.59
- Zoom Type
- Manual
- Zoom Factor
- 1.96x
- Vertical Lens Shift
- 80% / 80%
- Horizontal Lens Shift
- 35% / 35%
Video Input
- Analogue video Signal
- RGB
- Video Interfaces
- VGA, HDMI, DisplayPort
- Video Modes
- 3 x HDMI - 19 pin HDMI Type A , 1 x HDMI output - 19 pin HDMI Type A , 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x DisplayPort - 20 pin DisplayPort , 1 x serial RS-232 , 1 x network - RJ-45 (management) , 1 x USB - 4 pin USB Type A , 1 x remote control
- Power Source
- AC
- Voltage Required
- AC 120/230 V
- 585 Watt
- Power Consumption Stand by
- 0.5 Watt
- 55 cm
- 50 cm
- 19.2 cm
- 16.5 kg
- 0 °C
- 40 °C
- 80%
- Sound Emission
- 32 dBA
- Sound Emission (Economic Mode)
- 29 dBA
