The professional Acer P7 series employs advanced technologies and convenient setup utilities to deliver clear, persuasive presentations in large business venues. Enterprising innovators like you will appreciate the high resolution, brightness and contrast ratio to drive your ventures toward greater success.
Remarkable visuals
This professional projector is the perfect workhorse for big meetings, presenting fantastically clear and vibrant images even in amply lit venues. Acer's advanced color technologies ensure color brilliance, and guarantee consistent image quality despite prolonged use. -
Wireless convenience
Experience true presentation freedom - project from any PC in the room over 802.11 b/g/n network, or use the MobiShow application to present from a Windows Mobile smartphone. You can also use the remote desktop feature to access content from any PC that's connected to the projector via LAN and has launched the Acer eProjection utility. What's more, the P7 series complies with the Crestron network system so you can control the projector over LAN. -
Installation flexibility
The Acer side-loading lamp design makes lamp replacement trouble-free, even while the projector remains ceiling-mounted. The keystone correction feature eliminates distortions resulting from elevated or side projection. Furthermore, with the display over USB feature, images from your PC can be displayed as soon as a USB cable connects the PC and projector.
- Acer P7505 - DLP projector - 3D - LAN
- DLP projector - 1080p
- 3D Capable
- Built-in Devices
- Stereo speakers
- Microdisplay
- DarkChip 3
- Brightness
- 5000 ANSI lumens
- Contrast Ratio
- 10000:1
- Resolution
- Full HD (1920 x 1080)
- Native Aspect Ratio
- 16:9
- Colour Support
- 1.07 billion colours
- Lens Shift Direction
- Horizontal, vertical
- Bulb type
- P-VIP 370 Watt
- Bulb life cycle
- Up to 2000 hour(s) - normal mode , Up to 4500 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video, component video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G), LAN
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V
- 460 Watt
- 39.8 cm x 31 cm x 13 cm
- 7 kg
- 3-year warranty
- 3D Capable
- Built-in Devices
- Stereo speakers
Projector
- Microdisplay
- DarkChip 3
- Brightness
- 5000 ANSI lumens
- Brightness (Reduced)
- 4000 ANSI lumens
- Contrast Ratio
- 10000:1
- Image Size
- 50 cm - 762 cm
- Projection Distance
- 1 m - 10 m
- Throw Ratio
- 1.5 - 2.28:1
- Uniformity
- 85 %
- Digital Zoom Factor
- 2x
- Resolution
- Full HD - Full HD (1920 x 1080) (native) / 1920 x 1200 (resized)
- 16:9
- Colour Support
- Max Sync Rate (V x H)
- 144 Hz x 100 kHz
- Bulb type
- P-VIP 370 Watt
- Bulb life cycle
- 6-segment colour wheel, BrilliantColor, USB host function, ColorBoost II+ Technology, Instant Pack Technology, DLP 3D Ready, SmartFormat Technology, EcoProjection Technology, 24p True Cinema, 4:3 aspect ratio support, SpectraBoost, Quick-Start
Lens
- Focus Type
- Manual
- Lens Aperture
- F/2.45-2.9
- Zoom Type
- Manual
- Zoom Factor
- 1.5x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
- Lens Shift Type
- Manual
- Vertical Lens Shift
- 12.5% / 12.5%
- Horizontal Lens Shift
- 15% / 15%
Video Input
- TV System
- PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, component video, composite video, S-Video
- Video Modes
- LAN and Wireless Image Transferring Protocols
- Wired LAN
Speakers
- Integrated
- Sound Output Mode
- Stereo
- Output Power / Channel
- 3 Watt
- Speakers
- 2 x right / left channel
- 1 x composite video input - RCA , 2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x S-video input - mini-DIN , 1 x component video input - RCA x 3 , 3 x HDMI - 19 pin HDMI Type A , 2 x audio line-in - mini-phone 3.5 mm , 2 x USB - 4 pin USB Type A , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone 3.5 mm , 1 x USB - 4 pin USB Type B (management) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45 , 1 x remote control - mini-phone 3.5 mm
- Included Accessories
- Carrying case, lens cover, wireless remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), PIN code
- TUV GS, FCC, ROSTEST
- Voltage Required
- AC 120/230 V
- 460 Watt
- Power Consumption Stand by
- 0.5 Watt
- 39.8 cm
- 31 cm
- 13 cm
- 7 kg
- Limited warranty - 3 years - pick-up and return , Limited warranty - lamp - 1 year , Limited warranty - DLP chipset - 5 years
- 0 °C
- 40 °C
- Sound Emission
- 36 dBA
- Sound Emission (Economic Mode)
- 30 dBA
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
