Acer P6500 DLP Projector
Quicklinx: C7SWWS00 Mfr#: MR.JMG11.001
With projection this crisp and bright, even your most complex concepts will be grasped easily by associates, clients or students. The high resolution and brilliant color of Acer’s Large-Venue Series projectors will let the power of your ideas shine through, and their top-notch technologies will keep you in complete control.
  • The Meeting Room Projector Family
    The projectors purpose-built for business meetings.
  • Clear Projection
    Deliver data clearly. The up to Full HD display projects with clarity and faithfully represents your presentation.
  • Comfortable Projection
    Acer's exclusive BlueLightShield works with the up to 4,500 lumens of brightness to deliver a comfortably bright view.
  • Wireless Projection
    Switching between devices has never been easier with hassle-free wireless projection.
  • Time-saving Projection
    Save time with auto keystone, so you can focus on what counts.
Acer P6500 - DLP projector - 3D - LAN
DLP projector - 1080p
3D Capable
Built-in Devices
Stereo speakers
Brightness
5000 lumens
Contrast Ratio
20000:1 (dynamic)
Resolution
Full HD (1920 x 1080)
Native Aspect Ratio
16:9
Colour Support
1.07 billion colours
Bulb type
UHP 365 Watt
Bulb life cycle
Up to 3000 hour(s) - normal mode , Up to 4500 hour(s) - economic mode
Video Input
RGB, S-Video, composite video, component video LAN
Speakers
Speaker(s) - integrated
460 Watt
36.9 cm x 29.4 cm x 11.6 cm
4.5 kg
3-year warranty
3D Capable
Built-in Devices
Stereo speakers
Projector
Brightness
5000 lumens
Contrast Ratio
20000:1 (dynamic)
Image Size
50 cm - 762 cm
Projection Distance
1 m - 9.4 m
Throw Ratio
1.41 - 2.24:1
Digital Zoom Factor
2x
Resolution
Full HD - Full HD (1920 x 1080) (native) / 1920 x 1200 (resized)
Native Aspect Ratio
16:9
Colour Support
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
UHP 365 Watt
Bulb life cycle
Lens
Focus Type
Manual
Lens Aperture
F/2.5-3.26
Zoom Type
Manual
Zoom Factor
1.6x
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, component video, composite video, S-Video
LAN and Wireless Image Transferring Protocols
Wired LAN
Speakers
Integrated
Sound Output Mode
Stereo
Output Power / Channel
10 Watt
Speakers
2 x right / left channel
1 x composite video input - RCA , 2 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x S-video input - 4 pin mini-DIN , 3 x component video input - RCA , 1 x HDMI - 19 pin HDMI Type A , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 2 x audio line-in - RCA , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (male) (management) , 1 x USB - 4 pin mini-USB Type B , 1 x USB - 4 pin USB Type A , 1 x network - RJ-45
Carrying case, lens cover, wireless remote control
1 x VGA cable , 1 x composite video cable , 1 x component video cable
Power Source
AC
460 Watt
36.9 cm
29.4 cm
11.6 cm
4.5 kg
Limited warranty - 3 years , Limited warranty - lamp - 1 year
Sound Emission
35 dB
30 dB
C7SW C2G 2m USB 2.0 A/B Cable - Black In Stock £3.61
