Acer P645  P648  P658  - PRODOCK 3 - 90W ADAPTER - UK POWER
Quicklinx: CPZ3WS00 Mfr#: NP.DCK11.018
The Acer Docking System matches ease-of-use with a future-proof solution to keep your business running smoothly.
Acer ProDock III - port replicator - VGA, DVI, HDMI - 1GbE
Port replicator
Video Interfaces
VGA, DVI, HDMI
40.85 cm x 12.316 cm x 1.925 cm
750 g
Gigabit Ethernet
Power adapter 90 Watt Power Provided
TravelMate P645, P648, P658
Port replicator
40.85 cm
12.316 cm
1.925 cm
750 g
2 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x display / video - DVI-Digital - 24+1 pin digital DVI , 1 x display / video - VGA - 15 pin HD D-Sub (HD-15) , 1 x audio / video - HDMI - 19 pin HDMI Type A , 1 x microphone - line-In - mini-phone 3.5 mm , 1 x headphones / speakers - line-out - mini-phone stereo 3.5 mm , 1 x audio / video - DisplayPort , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 2 x SuperSpeed USB 3.0 with power off USB charging - 9 pin USB Type A
Security lock slot (cable lock sold separately), wake on LAN
Power adapter
Power Provided
90 Watt
Acer TravelMate P645-S-37AZ, P645-S-39JZ, P645-S-5107, P645-S-511A, P645-S-51MT, P645-S-52TF, P645-S-54BV, P645-S-58KU, P645-S-59TP, P645-SG-721K, P645-SG-79XS, P648-M-34W4, P648-M-39ST, P648-M-502Q, P648-M-505W, P648-M-50K3, P648-M-50KW, P648-M-50SB, P648-M-518U, P648-M-51XB, P648-M-5236, P648-M-52K4, P648-M-52KD, P648-M-531K, P648-M-533L, P648-M-53DA, P648-M-53FA, P648-M-53ZU, P648-M-5423, P648-M-5499, P648-M-549F, P648-M-54DG, P648-M-54L4, P648-M-54W4, P648-M-54WM, P648-M-55M2, P648-M-55NV, P648-M-55PR, P648-M-55W2, P648-M-56GL, P648-M-56J0, P648-M-56K0, P648-M-56ZR, P648-M-5727, P648-M-57NA, P648-M-57S3, P648-M-57V7, P648-M-57VS, P648-M-57XT, P648-M-5863, P648-M-58J5, P648-M-5918, P648-M-5976, P648-M-59CU, P648-M-59KB, P648-M-59KW, P648-M-59Q7, P648-M-700F, P648-M-70DK, P648-M-70GA, P648-M-70KS, P648-M-70QW, P648-M-72CK, P648-M-73LE, P648-M-73NG, P648-M-73WE, P648-M-746Z, P648-M-7494, P648-M-74JT, P648-M-74LB, P648-M-74YM, P648-M-757N, P648-M-76EA, P648-M-76Y5, P648-M-777F, P648-M-78BD, P648-M-78T2, P648-M-79FW, P648-M-79XQ, P648-MG-38K6, P648-MG-5136, P648-MG-53LH, P648-MG-554H, P648-MG-720A, P648-MG-731C, P648-MG-75T9, P648-MG-76WH, P648-MG-77DL, P648-MG-77EC, P648-MG-77HQ, P648-MG-789T, P648-MG-7966, P648-MG-79S4, P658-M-35JP, P658-M-50HL, P658-M-50NJ, P658-M-50WW, P658-M-51AT, P658-M-51GQ, P658-M-51MF, P658-M-51ML, P658-M-51U5, P658-M-52AM, P658-M-52TS, P658-M-52WN, P658-M-537B, P658-M-53JQ, P658-M-53WZ, P658-M-547D, P658-M-548J, P658-M-54V8, P658-M-54YF, P658-M-554G, P658-M-55A5, P658-M-55SS, P658-M-567U, P658-M-583W, P658-M-58FV, P658-M-58V8, P658-M-59J7, P658-M-59JF, P658-M-59SW, P658-M-59SY, P658-M-70BQ, P658-M-70S3, P658-M-719E, P658-M-71XA, P658-M-72F9, P658-M-72WF, P658-M-73FG, P658-M-746R, P658-M-749U, P658-M-76PG, P658-M-77CQ, P658-M-78Y3, P658-M-79GJ, P658-MG-509B, P658-MG-51J7, P658-MG-53NZ, P658-MG-59JV, P658-MG-7060, P658-MG-72FE, P658-MG-73JY, P658-MG-749P, P658-MG-74QM, P658-MG-74V8
