With projection this crisp and bright, even your most complex concepts will be grasped easily by associates, clients or students. The high resolution and brilliant color of Acer’s Large-Venue Series projectors will let the power of your ideas shine through, and their top-notch technologies will keep you in complete control.
- Acer P6200S - DLP projector - 3D - LAN
- DLP projector
- 3D Capable
- Built-in Devices
- Stereo speakers
- Localisation
- United Kingdom, Europe
- Brightness
- 5000 lumens
- Contrast Ratio
- 20000:1 (dynamic)
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Bulb type
- UHP
- Bulb life cycle
- Up to 3000 hour(s) - normal mode , Up to 4500 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video, component video LAN
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V
- 383 watt
- 36.9 cm x 29.4 cm x 11.6 cm
- 4.5 kg
- DLP projector
- 3D Capable
- Built-in Devices
- Stereo speakers
- Localisation
Projector
- Brightness
- 5000 lumens
- Contrast Ratio
- 20000:1 (dynamic)
- Image Size
- 66 cm - 762 cm
- Projection Distance
- 1 m - 8.6 m
- Throw Ratio
- 1.4 - 1.91:1
- Digital Zoom Factor
- 2x
- Resolution
- XGA - XGA (1024 x 768) (native) / 1920 x 1200 (resized)
- 4:3
- Max Sync Rate (V x H)
- 120 Hz x 100 kHz
- Bulb type
- UHP
- Bulb life cycle
- 16:9 aspect ratio support
Lens
- Focus Type
- Manual
- Lens Aperture
- F/2.5-2.93
- Zoom Type
- Manual
- Zoom Factor
- 1.4x
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -30 / +30
- Horizontal Keystone Correction
- -30 / +30
Video Input
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, component video, composite video, S-Video
- LAN and Wireless Image Transferring Protocols
- Wired LAN
Speakers
- Integrated
- Sound Output Mode
- Stereo
- Output Power / Channel
- 10 watt
- Speakers
- 2 x right / left channel
- 1 x composite video input - RCA , 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x S-video input - mini-DIN , 1 x component video input - RCA x 3 , 3 x HDMI - 19 pin HDMI Type A , 1 x audio line-in - mini-phone 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone 3.5 mm , 1 x USB - 4 pin mini-USB Type B , 1 x network - RJ-45
- Included Accessories
- Carrying case, lens cover, wireless remote control
- Cables Included
- 1 x component video cable , 1 x composite video cable , 1 x VGA cable
- Power Source
- AC
- Voltage Required
- AC 120/230 V
- 383 watt
- 36.9 cm
- 29.4 cm
- 11.6 cm
- 4.5 kg
- 0 °C
- 40 °C
- Sound Emission
- 33 dB
- Sound Emission (Economic Mode)
- 28 dB
