- Acer P1502 - DLP projector - portable - 3D
- DLP projector - 1080p
- 3D Capable
- Yes (3D glasses sold separately)
- Built-in Devices
- Speaker
- Microdisplay
- DarkChip 3
- Brightness
- 3400 ANSI lumens
- Contrast Ratio
- 16000:1 (dynamic)
- Resolution
- Full HD (1920 x 1080)
- Native Aspect Ratio
- 16:9
- Colour Support
- 1.07 billion colours
- Bulb type
- UHP 203 Watt
- Bulb life cycle
- Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Video Input
- RGB, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - internal
- Power
- AC 120/230 V
- 235 Watt
- 31.5 cm x 21.4 cm x 9.8 cm
- 2.7 kg
- 3D Capable
- Built-in Devices
- Speaker
Projector
- Microdisplay
- DarkChip 3
- Brightness
- 3400 ANSI lumens
- Brightness (Reduced)
- 2720 ANSI lumens
- Contrast Ratio
- 16000:1 (dynamic)
- Image Size
- 78 cm - 762 cm
- Projection Distance
- 1 m - 7.5 m
- Throw Ratio
- 1.13 - 1.47:1
- Uniformity
- 85 %
- Digital Zoom Factor
- 2x
- Resolution
- Full HD - Full HD (1920 x 1080) (native) / 1920 x 1200 (resized)
- 16:9
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 100 kHz
- Bulb type
- UHP 203 Watt
- Bulb life cycle
- BrilliantColor, Instant Pack Technology, DLP 3D Ready, SmartFormat Technology, EcoProjection Technology, 4:3 aspect ratio support, Acer ColorSafe II Technology, Quick-Start, ColorBoost 3D Technology, Acer LumiSense+
Lens
- Focus Type
- Manual
- Lens Aperture
- F/2.5-2.78
- Zoom Type
- Manual
- Zoom Factor
- 1.3x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, MHL
- Video Modes
Speakers
- Internal
- Sound Output Mode
- Mono
- Output Power / Channel
- 3 Watt
- Speakers
- 1 x mixed channel
- 1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x serial RS-232 (management) , 1 x USB - 4 pin USB Type A
- Included Accessories
- Wireless remote control
- Power Source
- AC
- Voltage Required
- AC 120/230 V
- 235 Watt
- Power Consumption Stand by
- 0.5 Watt
- 31.5 cm
- 21.4 cm
- 9.8 cm
- 2.7 kg
- 0 °C
- 40 °C
- Sound Emission
- 31 dBA
- Sound Emission (Economic Mode)
- 28 dBA
