Acer Essential series projectors are the optimal projectors ideal for everyday use, at work or home. Make your presentations more compelling and entertainment more exciting with high brightness, high contrast and DLP 3D ready, while adhering to your bottom line.
- Acer P1287 - DLP projector - portable - 3D
- DLP projector
- 3D Capable
- Yes (3D glasses sold separately)
- Brightness
- 4200 lumens
- Contrast Ratio
- 17000:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Bulb life cycle
- Up to 3000 hour(s) - normal mode , Up to 5000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video (NTSC)
- 31.4 cm x 22.3 cm x 9.3 cm
- 2.5 kg
- DLP projector
- 3D Capable
Projector
- Brightness
- 4200 lumens
- Brightness (Reduced)
- 3360 lumens
- Contrast Ratio
- 17000:1
- Image Size
- 127 cm - 762 cm
- Projection Distance
- 1.6 m - 9.7 m
- Resolution
- XGA - XGA (1024 x 768) (native) / 1920 x 1200 (resized)
- 4:3
- Max Sync Rate (V x H)
- 120 Hz
- Bulb life cycle
- Instant Pack Technology, DLP 3D Ready, Auto Vertical Keystone, SmartFormat Technology, 16:9 aspect ratio support, EcoProjection Technology, 4:3 aspect ratio support, Acer ColorSafe II Technology, MHL compliance, ColorBoost 3D Technology
Lens
- Focus Type
- Manual
- Lens Aperture
- F/2.41-2.7
- Zoom Type
- Manual
- Zoom Factor
- 1.1x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- NTSC
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video, MHL
- 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - mini-DIN , 2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB - 4 pin mini-USB Type B (management) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 2 x audio line-in - mini-phone 3.5 mm
- 31.4 cm
- 22.3 cm
- 9.3 cm
- 2.5 kg
- Sound Emission
- 34 dBA
- Sound Emission (Economic Mode)
- 29 dBA
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
C2G 5m Select High Speed HDMI with Ethernet | In Stock | £20.51 |
C2G 15m Select High Speed HDMI with Ethernet | In Stock | £53.35 |
