Acer P1285B TCO DLP XGA 3D 3200 Lumens Projector
Quicklinx: BCW7WS00 Mfr#: MR.JM011.002
Acer Essential series projectors are best value projectors ideal for everyday use, at work or home. Make your presentations more compelling and entertainment more exciting with high brightness, high contrast and DLP 3D Ready, while adhering to your bottom line.
  • Bright and Vivid
    With WXGA resolution, high brightness, high contrast and Acer Color Technology, your presentations will be more compelling with sharper texts and vibrant images, even from a distance. Combined with DLP 3D Ready you can also enjoy an immersive theater-like 3D entertainment experience.
  • Acer Dust Shield
    The accumulation of dust over time can cause a projector to not function properly and lose its original brightness. With Acer Dust Shield, Essential series projectors can defend against the detrimental effects of dust, allowing them to work better, for longer, and requiring less maintenance.
  • Convenient and flexible
    Essential series projectors have features that make them easy to use including 9 key control panels on the top of the projectors and 40-degree keystone correction that automatically adjusts vertical distortions. Their ceiling mounts provide four ways to install them so you can pick the method that best suits your needs.
  • Eco-smart
    Essential series projectors sport eco-friendly technologies that are better for the planet and good for your wallet. Their standby power consumption can be reduced by 90% and by 70% when powered on, which helps to prolong the lifespan of its lamps (Up to 10,000 hours) for lower replacement costs.
Acer P1285B - DLP projector - portable - 3D - LAN
DLP projector
3D Capable
Yes (3D glasses sold separately)
Brightness
3200 lumens
Contrast Ratio
20000:1 (dynamic)
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Bulb life cycle
Up to 4000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video LAN
Speakers
Speaker(s) - internal
30.8 cm x 21.1 cm x 8.6 cm
2.3 kg
3-year warranty
DLP projector
3D Capable
Projector
Brightness
3200 lumens
Brightness (Reduced)
2560 lumens
Contrast Ratio
20000:1 (dynamic)
Throw Ratio
1.86 - 2.04:1
Resolution
XGA - XGA (1024 x 768) (native) / 1920 x 1200 (resized)
Native Aspect Ratio
4:3
Bulb life cycle
DLP 3D Ready, Auto Vertical Keystone, SmartFormat Technology, EcoProjection Technology, Acer ColorSafe II Technology, ColorBoost 3D Technology
Lens
Focus Type
Manual
Lens Aperture
F/2.56-2.8
Zoom Type
Manual
Zoom Factor
1.1x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video, MHL
LAN and Wireless Image Transferring Protocols
Wired LAN
Speakers
Internal
Sound Output Mode
Mono
Output Power / Channel
10 Watt
Speakers
1 x mixed channel
2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - mini-DIN , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x USB - 4 pin mini-USB Type B , 1 x serial RS-232 (management) , 2 x Mobile High-Definition Link (MHL) / HDMI , 2 x USB - 4 pin USB Type A , 1 x network - RJ-45
Carrying case, remote control
1 x VGA cable
Power Source
AC
30.8 cm
21.1 cm
8.6 cm
2.3 kg
Limited warranty - 3 years - carry-in , Limited warranty - lamp - 1 year
Sound Emission
30 dBA
26 dBA
BCW7 C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
