Acer P1155 DLP SVGA 4000 Lumens Projector
Quicklinx: FVNDWS00 Mfr#: MR.JSH11.002
With projection this crisp and bright, even your most complex concepts will be grasped easily by associates, clients or students. The high resolution and brilliant color of Acer’s Large-Venue Series projectors will let the power of your ideas shine through, and their top-notch technologies will keep you in complete control.
  • Enhanced audio experience
    With an integrated speaker system delivering 3 W of output power, this projector offers a mono sound output mode, ensuring clear and powerful audio for presentations and multimedia content.
  • Vivid visuals
    Boasting a brightness of 4000 ANSI lumens and supporting 1.07 billion colors, the Acer P1155 provides vibrant and sharp images. Its SVGA (800 x 600) native resolution, combined with a dynamic contrast ratio of 20,000:1, ensures crisp and detailed visuals for an immersive viewing experience.
  • Versatile connectivity
    Equipped with a wide range of interfaces including HDMI, VGA input and output, USB, and audio line-in/out, this projector offers flexible connection options for various devices, making it ideal for both personal and professional use.
  • Long-lasting performance
    The projector lamp has a life cycle of up to 15,000 hours in extreme economic mode, reducing the need for frequent lamp replacements and ensuring long-term reliability and lower total cost of ownership.
  • Portable and user-friendly
    With features like vertical keystone correction, a compact form factor, and Acer's exclusive ColorSafe II and ColorBoost 3D technologies, the P1155 is not only easy to set up in any setting but also ensures consistent, true-to-life colors over time.
Acer P1155 - DLP projector - portable - 3D
DLP projector
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Speaker
United Kingdom
Microdisplay
DarkChip 3
Brightness
4000 ANSI lumens
Contrast Ratio
20000:1 (dynamic)
Resolution
SVGA (800 x 600)
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Bulb type
UHP 203 Watt
Bulb life cycle
Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode , Up to 15000 hour(s) - extreme economic mode
Speakers
Speaker(s) - integrated
AC 120/230 V
30 cm x 22 cm x 9.2 cm
2.25 kg
3-year warranty
DLP projector
3D Capable
Built-in Devices
Speaker
United Kingdom
Projector
Microdisplay
DarkChip 3
Brightness
4000 ANSI lumens
Brightness (Reduced)
3200 ANSI lumens
Contrast Ratio
20000:1 (dynamic)
Projection Distance
1 m - 12 m
Throw Ratio
1.96 - 2.15:1
Uniformity
85 %
Digital Zoom Factor
2x
Resolution
SVGA - SVGA (800 x 600)
Native Aspect Ratio
4:3
Colour Support
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
UHP 203 Watt
Bulb life cycle
DLP 3D Ready, SmartFormat Technology, 16:9 aspect ratio support, Acer ColorSafe II Technology, ColorBoost 3D Technology
Lens
Lens Aperture
F/2.56-2.68
Zoom Factor
1.1x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
Video Interfaces
VGA, HDMI, composite video, MHL
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
3 Watt
Speakers
1 x mixed channel
1 x HDMI - 19 pin HDMI Type A , 1 x Mobile High-Definition Link (MHL) / HDMI , 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232 , 1 x USB - 4 pin USB Type A , 1 x audio line-in - mini-phone 3.5 mm , 1 x audio line-out - mini-phone 3.5 mm , 1 x composite video input - RCA
Carrying case, remote control, battery for remote control, security card
1 x VGA cable
Power Source
AC
AC 120/230 V
30 cm
22 cm
9.2 cm
2.25 kg
Limited warranty - 3 years - carry-in , Limited warranty - lamp - 1 year
Sound Emission
31 dB
27 dB
