Acer KG281KAbmiipx 28" 3840x2160 1ms HDMI DisplayPort LED Monitor
Quicklinx: G0GLWS00 Mfr#: UM.PX1EE.A04
The stylish three-pronged stand saves on desk space without sacrificing style. The ZeroFrame design makes for a near-seamless look, allowing you to see more of what matters most: the screen.
Screen tearing will be a thing of the past with AMD FreeSync which syncs your display's frame rate to the video card. A quick response means images refresh quickly, making your gaming sessions seamless and enjoyable.
  • A stand with style
  • ZeroFrame design
  • An ergonomic edge
    Good monitors should cause little to no strain. With a tilt of -5° to 15°, you can put your mind, and your neck, at ease.
  • Game with AMD FreeSync
  • Quick response time
Acer KG281K Abmiipx - LED monitor - 28"
LED-backlit LCD monitor - 28"
Energy Class
Class B
Energy Consumption per Year
58 kWh
Power Consumption (On mode)
40 W
Adaptive-Sync Technology
AMD FreeSync
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
4K UHD (2160p) 3840 x 2160 at 60 Hz
Pixel Pitch
0.16 mm
Brightness
330 cd/m²
Response Time
1 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
65.9 cm x 24.1 cm x 48.2 cm
5.49 kg
FCC Class B certified, MPR II, UL, TUV GS, VCCI, cUL, RoHS
Display Type
Energy Class
Class B
58 kWh
Diagonal Size
28"
AMD FreeSync
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.16 mm
Brightness
330 cd/m²
Colour Support
Response Time
1 ms (grey-to-grey)
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Anti-glare
Backlight Technology
LED backlight
10-bit gamma, ComfyView, Zero Frame, Flicker-Less technology, Low Dimming technology, Acer VisionCare, Acer BluelightShield technology
65.9 cm x 24.1 cm x 48.2 cm - with stand
5.49 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
DisplayPort , 2 x HDMI , Audio line-out
Mechanical
Tilt
Tilt Angle
-5/+15
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support
1 x DisplayPort cable
Security Slot Type
Kensington security slot
Input Voltage
40 W
Power Consumption (Typical)
34 Watt
Power Consumption Stand by
0.37 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
With stand - width: 65.9 cm - depth: 24.1 cm - height: 48.2 cm - weight: 5.49 kg , Without stand - width: 65.9 cm - depth: 6.5 cm - height: 38.2 cm - weight: 4.96 kg
Shipping Width
73.1 cm
Shipping Depth
14.7 cm
Shipping Height
48.9 cm
Shipping Weight
7.83 kg
