Acer KA241Y  23.8"1920 x 1080 4ms HDMI DVI LED Monitor
Quicklinx: DFTMWS00 Mfr#: UM.QX1EE.005
Prolonged screen viewing can cause your eyes to become sore and fatigued. Luckily, Acer KA1 series monitors help to lessen these nasty side effects with technologies that reduce screen flicker, ambient glare and irritating blue light.
  • Adapts to your environment
    Low dimming technology adjusts screen brightness based on ambient light. When your surroundings are brightly lit, they'll turn brightness up. Conversely when it's dark, they can adjust down.
  • Place it right
    The position of the screen is also important in ensuring a comfortable viewing experience. Therefore, KA1 series monitors are equipped with adjustable ergonomic screens that can be titled.
Acer KA241Y - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class F
Energy Consumption per Year
38 kWh
Power Consumption (On mode)
21.8 W
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
AC 120/230 V
54 cm x 21.3 cm x 42.2 cm
4.11 kg
MPR II
Display Type
Energy Class
Class F
38 kWh
Diagonal Size
23.8"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Low Dimming technology
54 cm x 21.3 cm x 42.2 cm - without stand
4.11 kg
DVI , HDMI , VGA , Audio line-out
Mechanical
Tilt
Tilt Angle
-5/+20
1 x VGA cable
MPR II
Security Slot Type
Kensington security slot
Input Voltage
AC 120/230 V
21.8 W
21.8 kWh/1000h
Power Consumption (Typical)
26 Watt
Power Consumption Stand by
0.35 Watt
Power Consumption (Off Mode)
0.35 Watt
Dimensions & Weight Details
Without stand - width: 54 cm - depth: 21.3 cm - height: 42.2 cm - weight: 4.11 kg
