The KA series is optimized for a comfortable viewing experience. The display is easy on the eyes with low response times and special technology to reduce glare. Easy adjustments and a wide viewing angle help you find the perfect position.
Optimized comfort
Sit back and get comfortable with Acer ComfyView technology to reduce reflective glare and Blue Light Filter Pro to remove harmful blue light without sacrificing color or brightness. Get a good view with convenient -5° to 15° tilt adjustment. -
Smart design
On-screen display buttons are conveniently located on the front of the device for easy access. The KA series is wall-mountable and has space for a Kensington lock for added security.
- Acer KA240HQ - LED monitor - Full HD (1080p) - 23.6"
- LED-backlit LCD monitor - 23.6"
- Energy Class
- Class F
- Energy Consumption per Year
- 39 kWh
- Power Consumption (On mode)
- 20.4 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Brightness
- 300 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 1 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI, VGA
- Tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V
- Black
- 56.7 cm x 19.2 cm x 43.46 cm
- Microsoft Certification
- Compatible with Windows 7
- MPR II
- 3-year warranty
- Display Type
- Energy Class
- Class F
- 39 kWh
- Diagonal Size
- 23.6"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 1 ms
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Acer Adaptive Contrast Management (ACM)
- Black
- 56.7 cm x 19.2 cm x 43.46 cm - with stand
- VGA , DVI , HDMI
Mechanical
- Tilt
- Tilt Angle
- -5/+15
- Cables Included
- 1 x VGA cable
- MPR II
- Security Slot Type
- Kensington security slot
- Input Voltage
- AC 120/230 V
- 20.4 W
- Power Consumption SDR (On mode)
- 20.4 kWh/1000h
- Power Consumption (Typical)
- 22 Watt
- Power Consumption Sleep
- 0.45 Watt
- 0.35 Watt
- On / Off Switch
- No
- Dimensions & Weight Details
- With stand - width: 56.7 cm - depth: 19.2 cm - height: 43.46 cm , Without stand - width: 56.7 cm - depth: 6.07 cm - height: 33.59 cm
- Limited warranty - 3 years
Accessories (5)
StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount | In Stock | £143.67 |
StarTech.com Articulating Monitor Arm | In Stock | £132.69 |
StarTech.com Dual Monitor Stand | In Stock | £91.00 |
StarTech.com TV/Monitor Arm - Wallmount | In Stock | £82.52 |
StarTech.com Monitor Arm - Heavy Duty | In Stock | £93.49 |
Other bundles (1)
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
