Acer KA240Hbid 24" 1920x1080 5ms VGA DVI HDMI LED Monitor
Quicklinx: G0JQWS00 Mfr#: UM.FX0EE.013
Choose more comfort and enjoy the excellent displays of the Acer KA series. The displays are gentle to the eyes with short response time and special technologies to reduce glare and reflections.
  • Great visuals
    See clearly with a beautiful Full HD display. A fast response time reduces ghosting and takes action-packed entertainment to a new level.
  • Optimized comfort
    Sit back and get comfortable with Acer ComfyView technology to reduce reflective glare. Get a good view with convenient -5° to 15° tilt adjustment.
  • Smart design
    On-screen display buttons are conveniently located on the front of the device for easy access. The KA series is wall-mountable and has space for a Kensington lock for added security.
Acer KA240Hbid - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/399711
Energy Class
Class F
Energy Consumption per Year
38 kWh
Power Consumption (On mode)
26 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.277 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 100000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Colour Gamut
72% NTSC
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
56.7 cm x 19.2 cm x 43.5 cm
3.74 kg
MPR II
Display Type
Energy Class
Class F
38 kWh
Diagonal Size
24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.277 mm
Pixel Per Inch
91.8
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72% NTSC
Response Time
5 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Acer Adaptive Contrast Management (ACM), ComfyView, 72% NTSC colour gamut
56.7 cm x 19.2 cm x 43.5 cm - with stand
3.74 kg
VGA , DVI , HDMI
Mechanical
Tilt
Tilt Angle
-5/+15
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support
1 x VGA cable
MTBF
30,000 hour(s)
MPR II
Security Slot Type
Kensington security slot
Input Voltage
26 W
22.5 kWh/1000h
Power Consumption (Typical)
20.9 Watt
Power Consumption Stand by
0.45 Watt
Power Consumption Sleep
0.45 Watt
Power Consumption (Off Mode)
0.35 Watt
On / Off Switch
No
Shipping Width
62.9 cm
Shipping Depth
42.2 cm
Shipping Height
12.1 cm
Shipping Weight
5.35 kg
