Acer KA240H 24" 1920x1080 5ms HDMI DVI VGA Black Monitor
Quicklinx: CNQKWS00 Mfr#: UM.FX0EE.005
The KA series is optimized for a comfortable viewing experience. The display is easy on the eyes with low response times and special technology to reduce glare.
  • Great visuals
    See clearly with a beautiful Full HD display. Opt for a vivid IPS panel with a 178° wide viewing angle or lightning-quick TN panel to suit your needs. A 1ms response time reduces ghosting and takes action-packed entertainment to a new level.
  • Optimized comfort
    Sit back and get comfortable with Acer ComfyView technology to reduce reflective glare and Blue Light Filter Pro to remove harmful blue light without sacrificing color or brightness. Get a good view with convenient-5° to 15° tilt adjustment.
  • Smart design
    On-screen display buttons are conveniently located on the front of the device for easy access. The KA series is wall-mountable and has space for a Kensington lock for added security.
Acer KA240H - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/399711
Energy Class
Class F
Energy Consumption per Year
38 kWh
Power Consumption (On mode)
22.5 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 100000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Colour Gamut
72% NTSC
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
AC 120/230 V
56.7 cm x 19.2 cm x 43.46 cm
Environmental Standards
ENERGY STAR Qualified
MPR II
3-year warranty
Display Type
Energy Class
Class F
38 kWh
Diagonal Size
24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72% NTSC
Response Time
5 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Acer Adaptive Contrast Management (ACM), 72% NTSC colour gamut
56.7 cm x 19.2 cm x 43.46 cm - with stand
VGA , DVI , HDMI
Mechanical
Tilt
Tilt Angle
-5/+15
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support
1 x VGA cable
MPR II
Security Slot Type
Kensington security slot
Input Voltage
AC 120/230 V
22.5 W
22.5 kWh/1000h
Power Consumption (Typical)
22 Watt
Power Consumption Stand by
0.45 Watt
Power Consumption Sleep
0.35 Watt
Dimensions & Weight Details
With stand - width: 56.7 cm - depth: 19.2 cm - height: 43.46 cm , Without stand - width: 56.7 cm - depth: 6.07 cm - height: 33.59 cm
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years - carry-in
CNQK StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £135.75
CNQK StarTech.com Articulating Monitor Arm In Stock £118.99
CNQK StarTech.com Dual Monitor Stand In Stock £80.12
CNQK StarTech.com TV/Monitor Arm - Wallmount In Stock £82.22
CNQK StarTech.com Monitor Arm - Heavy Duty In Stock £93.15
