Eco-friendly Acer K2 Series monitors are affordable display solutions for everyday PC usage. They offer hassle-free usability without compromising image quality. The intelligent design brings together a multitude of connection ports, superb performance, and eco-friendliness - all at a price point that'll make you smile.
You'll enjoy tasks and entertainment more on this LED-backlit display with the fine details which comes thanks to a Full HD resolution. The great sights are made even better by exceptional colors via Acer Adaptive Contrast Management.
The ComfyView display prevents reflections to provide greater eye comfort. It also delivers brighter colors for you viewing enjoyment. Set the K2 Series' display angle to optimize your view with its ergonomic stand that tilts from -5 to 25 degrees.
Great visuals
See clearly with a beautiful Full HD display. Opt for a vivid IPS panel with a 178° wide viewing angle or lightning-quick TN panel to suit your needs. A 1ms response time reduces ghosting and takes action-packed entertainment to a new level. -
Optimized comfort
Sit back and get comfortable with Acer ComfyView technology to reduce reflective glare and Blue Light Filter Pro to remove harmful blue light without sacrificing color or brightness. Get a good view with convenient-5° to 15° tilt adjustment. -
Smart design
On-screen display buttons are conveniently located on the front of the device for easy access. The KA series is wall-mountable and has space for a Kensington lock for added security.
- Acer KA220HQ - LED monitor - Full HD (1080p) - 21.5"
- LED-backlit LCD monitor - 21.5"
- Energy Class
- Class F
- Energy Consumption per Year
- 38 kWh
- Power Consumption (On mode)
- 19 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Brightness
- 200 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI, VGA
- Tilt
- Voltage
- AC 120/230 V
- Black
- 50.8 cm x 16.4 cm x 40.24 cm
- Microsoft Certification
- Compatible with Windows 7
- MPR II
- 3-year warranty
- Display Type
- Energy Class
- Class F
- 38 kWh
- Diagonal Size
- 21.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 200 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Backlight Technology
- LED backlight
- Acer Adaptive Contrast Management (ACM)
- Black
- 50.8 cm x 16.4 cm x 40.24 cm - with stand
- VGA , DVI , HDMI
Mechanical
- Tilt
- Tilt Angle
- -5/+15
- Cables Included
- 1 x VGA cable
- MPR II
- Security Slot Type
- Kensington security slot
- Input Voltage
- AC 120/230 V
- 19 W
- Power Consumption SDR (On mode)
- 19 kWh/1000h
- Power Consumption (Typical)
- 19.5 Watt
- Power Consumption Stand by
- 0.45 Watt
- 0.35 Watt
- Dimensions & Weight Details
- With stand - width: 50.8 cm - depth: 16.4 cm - height: 40.24 cm , Without stand - width: 50.8 cm - depth: 5.2 cm - height: 30.45 cm
- Limited warranty - 3 years
Accessories (5)
StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount | In Stock | £143.67 |
StarTech.com Articulating Monitor Arm | In Stock | £132.69 |
StarTech.com Dual Monitor Stand | In Stock | £91.00 |
StarTech.com TV/Monitor Arm - Wallmount | In Stock | £82.52 |
StarTech.com Monitor Arm - Heavy Duty | In Stock | £93.49 |
Other bundles (1)
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
