Acer K335 WXGA DLP 1000 Lumens Ultra Portable Projector
Quicklinx: 9JQCWS00 Mfr#: MR.JG711.001
The Acer K335 is also equipped with a SD card reader and a USB port allowing multimedia playback directly from a USB drive or memory card. Plus, with built-in office and PDF document reader support, they can project Office or PDF files without using a PC. Users can watch and share a variety of multimedia contents, including photos, audio and videos without the added burden of a notebook.
Acer K335 - DLP projector - portable - 3D
DLP projector
3D Capable
Built-in Devices
Speaker, card reader
Brightness
1000 lumens
Contrast Ratio
10000:1 (dynamic)
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Bulb type
LED
Bulb life cycle
Up to 20000 hours - normal mode , Up to 30000 hours - economic mode
Video Input
RGB, composite video (NTSC, SECAM, PAL)
Supported Memory Cards
SD Memory Card
Speakers
Speaker(s) - integrated
AC 120/230 V
23.2 cm x 16.6 cm x 4.63 cm
1.3 kg
DLP projector
3D Capable
Built-in Devices
Projector
Brightness
1000 lumens
Contrast Ratio
10000:1 (dynamic)
Image Size
76.2 cm - 254 cm
Projection Distance
0.9 m
Digital Zoom Factor
1.7x
Resolution
WXGA - WXGA (1280 x 800) (native) / 1920 x 1080 (resized)
Native Aspect Ratio
16:10
Colour Support
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
LED
Bulb life cycle
Lens
Focus Type
Manual
Lens Aperture
F/1.5
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
NTSC, SECAM, PAL
Analogue video Signal
SD Memory Card
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
3 Watt
Speakers
1 x mixed channel
Expansion Slots
1 x SD Memory Card
1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x HDMI - 19 pin HDMI Type A , 1 x USB - 4 pin USB Type A , 1 x composite video/audio input - mini-phone 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB - mini-USB Type B
Carrying case, wireless remote control
1 x VGA cable , 1 x composite video cable
Security Features
AC 120/230 V
23.2 cm
16.6 cm
4.63 cm
1.3 kg
Limited warranty - 2 years - carry-in
