Acer K272HULE LED Monitor 27" 2560 x 1440 TN 350 cd/m Black
Quicklinx: CCRSWS00 Mfr#: UM.HX2EE.E01
Eco-friendly Acer K2 series monitors are affordable display solutions for everyday PC usage. They offer hassle-free usability without compromising image quality. The intelligent design brings together a multitude of connection ports, superb performance, and eco-friendliness - all at a price point that'll make you smile.
  • Stunning performance
    You'll enjoy tasks and entertainment more on this LED-backlit display with the fine details which comes thanks to a Full HD resolution.
  • Comfortable views
    The ComfyView display prevents reflections to provide greater eye comfort. It also delivers brighter colors for you viewing enjoyment.
  • Smart design
    Set the K2 series' display angle to optimize your view with its ergonomic stand that tilts from -5 to 25 degrees.
  • Environment-friendly
    Safe for you and your world, K2 series monitors feature mercury-free LED backlighting. Acer EcoDisplay technologies use arsenic-free display glass, further protecting the environment.
Acer K272HULE - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
58 kWh
Power Consumption (On mode)
40 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
2560 x 1440
Brightness
350 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
1 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI
Display Position Adjustments
Tilt
61.4 cm x 24.8 cm x 44.92 cm
6.8 kg
Spain
Display Type
Energy Class
Class B
58 kWh
Diagonal Size
27"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
2560 x 1440
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms
Backlight Technology
LED backlight
61.4 cm x 24.8 cm x 44.92 cm - with stand
6.8 kg
Audio
Speakers
DVI , HDMI
Mechanical
Tilt
Tilt Angle
-5/+25
Spain
40 W
Power Consumption (Typical)
28.14 Watt
Power Consumption Sleep
0.36 Watt
Power Consumption (Off Mode)
0.25 Watt
On / Off Switch
Dimensions & Weight Details
With stand - width: 61.4 cm - depth: 24.8 cm - height: 44.92 cm - weight: 6.8 kg , Without stand - width: 61.4 cm - depth: 6.5 cm - height: 36.68 cm - weight: 5.48 kg
CCRS StarTech.com Dual Monitor Mount - Stackable In Stock £222.28
CCRS StarTech.com TV/Monitor Arm - Wallmount In Stock £82.22
CCRS StarTech.com Monitor Arm - Heavy Duty In Stock £93.15
CCRS StarTech.com Monitor Desk Mount - Steel In Stock £45.93
