Acer K272HLEbid 27'' 4ms DVI HDMI LED ZeroFrame Monitor
Quicklinx: CDLQWS00 Mfr#: UM.HX3EE.E04
Eco-friendly Acer K2 Series monitors are affordable display solutions for everyday PC usage. They offer hassle-free usability without compromising image quality. The intelligent design brings together a multitude of connection ports, superb performance, and eco-friendliness - all at a price point that'll make you smile.
Acer K272HLE - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class F
Energy Consumption per Year
59 kWh
Power Consumption (On mode)
41 W
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
4 ms
Colour Support
16.7 million colours
Colour Gamut
72% NTSC
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Tilt
Screen Coating
3H Hard Coating
Glossy black
64 cm x 23.5 cm x 46.3 cm
5 kg
Environmental Standards
ENERGY STAR Qualified
MPR II, TUV, GS, ISO 9241-307
Display Type
Energy Class
Class F
59 kWh
Diagonal Size
27"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Pixel Per Inch
82
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72% NTSC
Response Time
4 ms
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
3H Hard Coating
Backlight Technology
LED backlight
HDCP, ComfyView, Zero Frame, Wide Viewing Angle, 72% NTSC colour gamut
Glossy black
5 kg
DVI (HDCP) , VGA , HDMI
Mechanical
Tilt
Tilt Angle
-5/+25
VESA Mounting Interface
100 x 100 mm
1 x VGA cable
MTBF
30,000 hours
41 W
26 kWh/1000h
Power Consumption (Typical)
6 watt
Power Consumption Stand by
0.35 watt
Power Consumption Sleep
0.45 watt
Power Consumption (Off Mode)
0.35 watt
Dimensions & Weight Details
Width: 70.6 cm - depth: 48 cm - height: 14.1 cm
Sustainability Information
ENERGY STAR Certified
Accessories (4)
CDLQ StarTech.com Dual Monitor Mount - Stackable In Stock £217.58
CDLQ StarTech.com TV/Monitor Arm - Wallmount In Stock £84.28
CDLQ StarTech.com Monitor Arm - Heavy Duty In Stock £95.48
CDLQ StarTech.com Monitor Desk Mount - Steel In Stock £45.02
Other bundles (1)
CDLQ C2G 2m HDMI to DVI-D Digital Video Cable In Stock £9.15
