Acer K242HQLCbid 23.6" 1920x1080 1ms VGA DVI HDMI Monitor
Quicklinx: CPDGWS00 Mfr#: UM.UX6EE.C01
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 4ms
Interfaces: DVI, HDMI, VGA (HD-15)
£90.28 ex VAT
£108.33 inc VAT
The eco-friendly Acer K2 series monitors are an affordable display solution for everyday PC use. They offer a hassle-free experience without compromising image quality. The intelligent design brings together a multitude of connections, superb performance, and eco-friendliness, all at a price point that'll make you smile.
  • Comfortable views
    The display prevents reflections to provide greater eye comfort. It also delivers brighter colors for you viewing enjoyment.
  • Smart design
    Set the K2 series' display angle to optimize your view with its ergonomic stand that tilts from -5 to 25 degrees.
Acer K242HQLC - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class B
Energy Consumption per Year
39 kWh
Power Consumption (On mode)
27 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2715 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 100000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Tilt
56.7 cm x 20.79 cm x 42.12 cm
4.24 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
MPR II
Display Type
Energy Class
Class B
39 kWh
27 W
Diagonal Size
24"
Viewable Size
23.6"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2715 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms (grey-to-grey)
Vertical Refresh Rate
55 - 75 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
HDCP, Acer EcoDisplay, 72% NTSC colour gamut, High Frame Rate Control (Hi-FRC)
56.7 cm x 20.79 cm x 42.12 cm - with stand
4.24 kg
DVI (HDCP) , VGA , HDMI
Mechanical
Tilt
Tilt Angle
-5/+25
VESA Mounting Interface
100 x 100 mm
VESA interface support
Stand
1 x VGA cable
MPR II
22 Watt
Power Consumption Stand by
0.45 Watt
Power Consumption Sleep
0.35 Watt
Dimensions & Weight Details
With stand - width: 56.7 cm - depth: 20.79 cm - height: 42.12 cm - weight: 4.24 kg , Without stand - width: 56.7 cm - depth: 6.07 cm - height: 33.59 cm - weight: 3.92 kg
ENERGY STAR Certified
Acer K242HQLCbid 23.6 Bundle deal on Acer K242HQLCbid 23.6" 1920x1080 1ms VGA DVI HDMI Monitor
£189.45
Diagonal Size: 24in
Response Time: 4ms
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Acer
Price Range Ex VAT: 50 - 100
