Acer K242HQK 23.6" 3840x2160 4ms DVI HDMI DP IPS 4K Monitor
Quicklinx: BL7MWS00 Mfr#: UM.UV6EE.001
The eco-friendly Acer K2 Series monitors are an affordable display solution for everyday PC use. They offer a hassle-free experience without compromising image quality. The intelligent design brings together a multitude of connections, superb performance, and eco-friendliness, all at a price point that'll make you smile.
  • Stunning performance
    You'll enjoy tasks and entertainment more on this LED-backlit display with the fine details which comes thanks to high resolution. The great sights are made even better by exceptional colors via Acer Adaptive Contrast Management.
  • Comfortable views
    The ComfyView display prevents reflections to provide greater eye comfort. It also delivers brighter colors for you viewing enjoyment.
  • Smart design
    Set the K2 Series' display angle to optimize your view with its ergonomic stand that tilts from -5 to 25 degrees.
  • Environment-friendly
    Safe for you and your world, K2 Series monitors use mercury-free white LED backlighting and meet ENERGY STAR 6.0 requirements. Acer EcoDisplay technologies use Arsenic free display glass, further protecting the environment. Acer packaging is made of recyclable materials, too.
Acer K242HQK - LED monitor - 23.6"
LED-backlit LCD monitor - 23.6"
Energy Class
Class B
Energy Consumption per Year
32 kWh
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K UHD (2160p) 3840 x 2160 (DisplayPort: 60 Hz, HDMI/MHL: 30 Hz, DVI: 30 Hz)
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 100000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, DisplayPort, MHL
Speakers
Integrated
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
56.7 cm x 21.83 cm x 42.02 cm
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
MPR II
Display Type
Energy Class
Class B
32 kWh
Diagonal Size
23.6"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Acer EcoDisplay, Acer Adaptive Contrast Management (ACM), ComfyView
56.7 cm x 21.83 cm x 42.02 cm - with stand
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
DVI-D (dual link) , DisplayPort , MHL / HDMI
Mechanical
Tilt
Tilt Angle
-5/+25
VESA Mounting Interface
100 x 100 mm
VESA interface support
Stand
1 x DVI cable , 1 x HDMI cable , 1 x DisplayPort cable
MPR II
Power Supply
Internal
Input Voltage
Power Consumption (Typical)
28.5 Watt
Power Consumption Stand by
0.45 Watt
Power Consumption Sleep
0.35 Watt
Dimensions & Weight Details
With stand - width: 56.7 cm - depth: 21.83 cm - height: 42.02 cm , Without stand - width: 56.7 cm - depth: 6.07 cm - height: 33.59 cm
Sustainability Information
ENERGY STAR Certified
BL7M C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black In Stock £14.57
