Full HD LED monitor
The 1920 x 1080 resolution of this LED monitor deliv ers excellent detail, making it perfect for advanced HD productivity and multimedia applications. LED monitors also consume less power and last longer than those with CC FL lamps. In addition, this monitor is mercury-free, ma king it safer for you and the environment.
Acer Adaptive Contrast Management
Acer Adaptive Contrast Management (ACM) optimizes contrast to present the highest level of clarity and detail by analyzing every scene, adjusting images frame by fram e, and enhancing detail and gradation. In addition, with ACM, the LCD monitor uses less power.
ComfyView
Acer ComfyView monitors reflect less ambient light to deliver vivid colors, reduced glare and more comfortable viewing, even over prolonged periods.
Acer Eco-Display
As part of our commitment to sustainable operations an d corporate social responsibility, Acer uses methods to carry out product design and material management distinctly meant to reduce environmental impact.
Display
- 24" Screen
- TN Panel
- LED Backlight
- Resolution: 1920 x 1080 @60Hz Full HD
- Response Time: 5ms
- Contrast ratio: 100,000,000:1
- Brightness: 250 cd/m2
- Viewing angle: 170°/ 160°
- Display Colours: 16.7m
- VGA
- DVI
- Tilt range: -5° to +25°
- HDCP Supported
- Anti-Glare
- VESA 100 x 100
Designed to adapt
Essential series monitors let you find the working angle that suits you best with a screen that tilts quickly and smoothly. The stand also has a magnetic area, great for holding paperclips and keeping your desk orderly. These monitors are also wall-mountable, giving you clear views with more room. -
Bright and clear
Focus more sharply on your tasks with the superior contrast ratios and ultra-quick response of these Full HD monitors. A range of built-in display technologies deliver consistent viewing across wide angles, faster response time for reduced eye strain, more realistic colors, and a stable view that prevents tailing when the screen is touched. -
Very connected
Collaborating with others is faster and more productive when you have plenty of ports available. Essential series monitors allow you to connect to a wide variety of devices like notebooks and tablets, thanks to DisplayPort, VGA, DVI and HDMI ports. -
Eco focus
Essential Series monitors are RoHS compliant and mercury free. Plus, you'll see significant power savings thanks to advanced Acer EcoDisplay technologies and white LED backlighting. More than 10% of the material used in these monitors is post-consumer recycled (PCR) plastic, further reducing environmental impact.
- Acer K242HLbd - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class F
- Energy Consumption per Year
- 34 kWh
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.276 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% NTSC
- Input Connectors
- DVI, VGA
- Tilt
- Glossy black
- 56.7 cm x 20.68 cm x 42.22 cm
- 3.57 kg
- Localisation
- United Kingdom, Europe, EMEA
- Environmental Standards
- ENERGY STAR Qualified
- MPR II
- 2-year warranty
- Display Type
- Energy Class
- Class F
- 34 kWh
- Diagonal Size
- 24"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.276 mm
- Pixel Per Inch
- 92
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72% NTSC
- Response Time
- 5 ms
- Vertical Refresh Rate
- 55 - 75 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Horizontal Viewing Angle
- 176
- Vertical Viewing Angle
- 170
- Backlight Technology
- LED backlight
- HDCP, Acer Adaptive Contrast Management (ACM), 72% NTSC colour gamut
- Glossy black
- 56.7 cm x 20.68 cm x 42.22 cm - with stand
- 3.57 kg
- DVI (HDCP) , VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+25
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable
- MTBF
- 30,000 hours
- MPR II
- Localisation
- Power Supply
- Internal
- Power Consumption SDR (On mode)
- 22 kWh/1000h
- Power Consumption (Typical)
- 6 Watt
- Power Consumption Stand by
- 0.35 Watt
- Power Consumption Sleep
- 0.45 Watt
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 2 years - carry-in
