Acer K242HLA 24" 1920x1080 5ms DVI VGA LED Monitor
Quicklinx: CLZ8WS00 Mfr#: UM.FW2EE.D01
The Acer K2 series monitors are affordable display solutions for everyday PC usage. They offer hassle-free usability without compromising image quality. The intelligent design brings together a multitude of connection ports, superb performance.
Acer K242HL - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/419936
Energy Class
Class F
Energy Consumption per Year
34 kWh
Power Consumption (On mode)
22 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
5 ms (On/Off)
Colour Support
16.7 million colours
Input Connectors
DVI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
56.7 cm x 20.7 cm x 42.19 cm
3.57 kg
EMEA
Environmental Standards
ENERGY STAR Qualified
MPR II
Display Type
Energy Class
Class F
34 kWh
Diagonal Size
24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (On/Off)
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Anti-glare
Backlight Technology
LED backlight
HDCP, Acer EcoDisplay, Acer Adaptive Contrast Management (ACM), High Frame Rate Control (Hi-FRC), ComfyView
56.7 cm x 20.7 cm x 42.19 cm - with stand
3.57 kg
DVI (HDCP) , VGA
Mechanical
Tilt
Tilt Angle
-5/+25
VESA Mounting Interface
100 x 100 mm
VESA interface support
1 x VGA cable
MPR II
EMEA
Input Voltage
22 W
22 kWh/1000h
Power Consumption (Typical)
20.09 Watt
Power Consumption Stand by
0.45 Watt
Power Consumption Sleep
0.35 Watt
Dimensions & Weight Details
Without stand - width: 56.7 cm - depth: 5.2 cm - height: 33.59 cm - weight: 3.1 kg , With stand - width: 56.7 cm - depth: 20.7 cm - height: 42.19 cm - weight: 3.57 kg
Sustainability Information
ENERGY STAR Certified
