Acer K222HQLBD 21.5" 1920x1080 5ms VGA DVI Black Monitor
Impressive 100 million:1 contrast ratio
Quicklinx: 9DJDWS00 Mfr#: UM.WW3EE.001
Diagonal Size: 21.5in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: None
Interfaces: DVI, VGA (HD-15)
11 in stock
£68.53 ex VAT
£82.23 inc VAT
The eco-friendly K2 Series value line is a cost effective display solution for everyday PC use, offering ease-of-use without compromising image quality.
The ultra-high contrast ratio is achieved via Adaptive Contrast Management (ACM), ensuring crystal clear viewing.
Fast 5ms Panel Response Time
The quick response time yields immersive graphics and video display
Enjoy the latest HD digital media
K2 Series features Full HD 1080p resolution.
  • Product Description: Acer K222HQLbd 21.5" Widescreen Monitor
  • Screen Size: LED-backlit LCD monitor - 21.5"
  • Aspect Ratio: Widescreen - 16:9
  • Native Resolution: FullHD 1920 x 1080 at 60 Hz
  • Brightness: 200 cd/m²
  • Contrast Ratio: 100000000:1 (dynamic)
  • Response Time: 5 ms (grey-to-grey)
  • Colour Support: 16.7 Million Colours
  • Connectivity: DVI, VGA
  • Speakers: No
  • HDCP: Acer Adaptive Contrast Management (ACM), 72% NTSC colour gamut
  • Height Adjustable: No
  • Vesa Mount: VESA 100 x 100
  • Warranty: 2 Year Warranty
  • Designed to adapt
    Essential Series monitors let you find the working angle that suits you best with a screen that tilts quickly and smoothly. The stand also has a magnetic area, great for holding paperclips and keeping your desk orderly. These monitors are also wall-mountable, giving you clear views with more room.
  • Bright and clear
    Focus more sharply on your tasks with the superior contrast ratios and ultra-quick response of these Full HD monitors. A range of built-in display technologies deliver consistent viewing across wide angles, faster response time for reduced eye strain, more realistic colors, and a stable view that prevents tailing when the screen is touched.
  • Very connected
    Collaborating with others is faster and more productive when you have plenty of ports available. Essential Series monitors allow you to connect to a wide variety of devices.
  • Eco focus
    Essential Series monitors mercury free. Plus, you'll see significant power savings thanks to advanced Acer EcoDisplay technologies and white LED backlighting.
Acer K222HQL bd - LED monitor - Full HD (1080p) - 21.5"
Energy Class
Class A
Energy Consumption per Year
29 kWh
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
200 cd/m²
Contrast Ratio
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI, VGA
Display Position Adjustments
Tilt
50.8 cm x 20.7 cm x 39.1 cm
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
MPR II
Display Type
Energy Class
Class A
29 kWh
Diagonal Size
21.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
200 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Horizontal Viewing Angle
90
Vertical Viewing Angle
65
Backlight Technology
LED backlight
HDCP, Acer Adaptive Contrast Management (ACM), ComfyView
DVI (HDCP) , VGA
Mechanical
Tilt
Tilt Angle
-5/+25
VESA Mounting Interface
100 x 100 mm
1 x VGA cable
MPR II
Power Supply
Internal
AC 120/230 V
18.1 Watt
Power Consumption Stand by
450 mW
Power Consumption Sleep
350 mW
Dimensions & Weight Details
With stand - width: 50.8 cm - depth: 20.7 cm - height: 39.1 cm , Without stand - width: 50.8 cm - depth: 30.5 cm - height: 5.2 cm
ENERGY STAR Certified
Acer K222HQLBD 21.5 Bundle deal on Acer K222HQLBD 21.5" 1920x1080 5ms VGA DVI Black Monitor
£167.70
Accessories (7)
9DJD StarTech.com Monitor Mount w/ Articulating Arm - Grommet or Desk Mount In Stock £64.11
9DJD StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £109.46
9DJD StarTech.com Articulating Monitor Arm In Stock £101.86
9DJD StarTech.com Dual Monitor Stand In Stock £69.36
9DJD StarTech.com Cubicle Monitor Hanger In Stock £45.29
9DJD StarTech.com TV/Monitor Arm - Wallmount In Stock £50.91
9DJD StarTech.com Monitor Arm - Heavy Duty In Stock £72.79
Other bundles (6)
9DJD C2G 1m DVI-D™ M/M Dual Link Digital Video Cable In Stock £7.89
9DJD C2G 2m DVI-D™ M/M Dual Link Digital Video Cable In Stock £9.23
9DJD C2G 5m DVI-D™ M/M Dual Link Digital Video Cable In Stock £16.77
9DJD C2G Velocity™ DVI-D™ Male to HDMI® Female Inline Adapter In Stock £5.00
9DJD C2G Velocity™ DVI-D™ Female to HDMI® Male Inline Adapter In Stock £7.57
9DJD C2G 2m HDMI to DVI-D Digital Video Cable In Stock £8.58
Response Time: 5ms
Speakers: None
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: Acer
Price Range Ex VAT: 50 - 100
