Everyday series monitor gives you the beauty you appreciate and the value you need. It showcases captivating widescreen visuals as well as eco-conscious features, making it perfect for enjoying marvelous multimedia at home or in your office, studio or study.
Slim and elegant
Everyday series monitor saves space and adds elegance to any area. -
Vivid
You'll enjoy tasks and entertainment more with fine details and smooth movement, thanks to high resolution, fast response time and superior contrast ratio. Games are more exciting and films truly cinematic when visuals are vibrant. Plus, the widescreen aspect ratio frames movies and HDTV content perfectly. -
Green
Safe for you and your world, Everyday series monitor is RoHS compliant, use mercury-free white LED backlighting and meet ENERGY STAR requirements. Acer EcoDisplay technologies deliver up to 68% power savings, further conserving energy and costs.
- Acer K202HQLb - LED monitor - 19.5"
- LED-backlit LCD monitor - 19.5"
- Energy Class
- Class F
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- 1600 x 900
- Brightness
- 200 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- VGA
- Tilt
- Voltage
- AC 120/230 V
- Black
- Dimensions (WxDxH) - without stand
- 46.34 cm x 5 cm x 27.62 cm
- 2.21 kg
- Localisation
- United Kingdom, Europe, EMEA
- Microsoft Certification
- Compatible with Windows 7
- MPR II
- 2-year warranty
- Display Type
- Energy Class
- Class F
- Diagonal Size
- 19.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- 1600 x 900
- Brightness
- 200 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms
- Vertical Refresh Rate
- 60 Hz
- Horizontal Viewing Angle
- 90
- Vertical Viewing Angle
- 65
- Backlight Technology
- LED backlight
- Acer Adaptive Contrast Management (ACM)
- Black
- 46.34 cm x 5 cm x 27.62 cm - without stand
- 2.21 kg
- VGA
Mechanical
- Tilt
- Cables Included
- 1 x VGA cable
- MPR II
- Localisation
- Input Voltage
- AC 120/230 V
- Power Consumption SDR (On mode)
- 16.7 kWh/1000h
- Power Consumption (Typical)
- 13.5 Watt
- Power Consumption Stand by
- 450 mW
- Power Consumption Sleep
- 350 mW
- Dimensions & Weight Details
- With stand - width: 46.34 cm - depth: 19.1 cm - height: 36.23 cm - weight: 2.7 kg , Without stand - width: 46.34 cm - depth: 5 cm - height: 27.62 cm - weight: 2.21 kg
- Limited warranty - 2 years - carry-in
