Acer K135i DLP WXGA 6000 Lumens 3D Projector
Quicklinx: B55VWS00 Mfr#: MR.JKW11.001
This projector supports MHL connectivity (via an MHL /HDMI port), which means it can display uncompressed HDMI audio/video from any smartphone or mobile device that supports MHL. This projector will also charge the battery of the connected mobile device. The user can also wirelessly connect this projector to such a mobile device by inserting Acer's unique MHL wireless adapter into the projector's MHL /HDMI port. In this way, this projector can wirelessly display the audio/video content of any device that supports Miracast Wi-Fi Display, WiDi Wireless Display or DLNA.
  • MHL connectivity
  • Acer ColorSafe II
    Acer projectors that feature ColorSafe II are virtually immune to color decay - the yellow or green tint of images displayed by some projectors that have been used for extended periods of time. Acer projectors with ColorSafe II take advantage of DLP technology and Acer's unique optics-based colorcompensation technology to guarantee picture integrity even after prolonged use. The resulting extended lifespan and consistent image quality lower the total cost of ownership.
  • Acer EcoProjection
    Acer EcoProjection with ExtremeEco is a complete environment-friendly power management solution that reduces standby power consumption by up to 70%. Also featured in the Acer EcoProjection suite is Acer ePower Management for customized power-saving configurations.
  • Presentation to Go
    The K135 offers 2 GB of internal memory, a micro SD card reader and USB multimedia readers that enable the Presentation To Go function: Full access to photos, videos, music and Office documents (PowerPoint, Excel, Word and PDF), directly from the projector - no need for a laptop PC or video player!
Acer K135i - DLP projector - 3D - with Acer UWA3 Wireless adapter
DLP projector
3D Capable
Yes (3D glasses sold separately)
Brightness
600 lumens
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Bulb type
LED
Bulb life cycle
Up to 20000 hours - normal mode , Up to 30000 hours - economic mode
Supported Memory Cards
SD Memory Card
Speakers
Speaker(s) - integrated
AC 120/230 V
65 Watt
430 g
Bundled with
DLP projector
3D Capable
Bundled with
Projector
Brightness
600 lumens
Image Size
43 cm - 254 cm
Projection Distance
0.6 m - 3.2 m
Throw Ratio
1.5:1
Resolution
WXGA - WXGA (1280 x 800) (native) / 1920 x 1080 (resized)
Native Aspect Ratio
16:10
Colour Support
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
LED
Bulb life cycle
Lens
Focus Type
Manual
Lens Aperture
F/2.0
Video Input
Video Interfaces
HDMI
SD Memory Card
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
2 Watt
Speakers
1 x mixed channel
1 x HDMI - 19 pin HDMI Type A , 1 x USB
Carrying case, remote control
AC 120/230 V
65 Watt
430 g
Limited warranty - 2 years - carry-in , Limited warranty - lamp - 1 year
5 °C
Sound Emission
33 dB
29 dB
B55V C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
