Acer Iconia Talk MediaTek MT8163 2GB 16GB eMMC 7" Andriod 6.0
Quicklinx: CPT4WS00 Mfr#: NT.LCCEE.007
With dual-SIM support, pre-installed Microsoft Office Suite and Google Mobile Services, work and play with just one device. Enjoy fast internet connectivity and data transfers for everything that you do on the go with 4G LTE. Not only is the Iconia Talk S ideal for the road, namely its portable form factor, perfectly-sized 7-inch IPS screen and textured anti-slip finish, it also has a bold camera ring design that will announce your arrival. A 13MP camera is there for you to capture your world clearly. Plus with the Acer EZ Utilities app, customize your Iconia Talk S to your liking, such as the size of the user-interface and sound preferences. If your kids will be using the device, keep inappropriate content out of sight with the Kids Center app.
  • Doubled down
    With the Iconia Talk S you get not only a high-powered tablet, but also a great phone with an extra twist. Dual SIM card sockets give you both the economy of two full-function, dual-standby phones, plus all the advantages of flexible account management and feature choices all with the savings of having two accounts in one phone.
  • All the angles
    A dream screen that's both bright and beautiful. The high-definition display uses IPS technology to bring out the details from all angles. Combine that with a Zero Air Gap design and you get brighter and crisper images with higher contrast and much better visibility in bright light.
  • Speed demon
    Designed to maximize performance with a quad-core processor the Iconia Talk S doesn't disappoint. Add the high-speed 4 G LTE mobile connectivity and you get a major increase in data transfer speed over previous mobile networks, while maintaining full backward compatibility with those networks when you need it.
  • Conveniences
    An effective anti-fingerprint coating reduces messy fingerprints and smudges, and makes the screen much easier to clean, while the narrow design improves single hand ease-of-use. Proportioned to enable thumb navigation and a one-hand grip, the elegant slim bezel design provides both increased comfort and added convenience.
Acer ICONIA Talk S A1-734-K96J - tablet - Android 6.0 (Marshmallow) - 16 GB - 7" - 4G
Tablet
Operating System
Display
7" IPS TFT - LED backlight - 1280 x 720 - Multi-Touch
MediaTek MT8735 (Quad-Core) - 64-bit
Processor Clock Speed
1.3 GHz
Storage
16 GB eMMC
RAM
2 GB
Supported Flash Memory Cards
microSD, SDHC Memory Card
Cellular Technology
4G
Cellular Protocols
LTE
Wireless Connectivity
802.11a/b/g/n, Bluetooth 4.0
Rear Camera
13 Megapixel
Front Camera
2 Megapixel
Navigation System
A-GPS/GPS/GLONASS
Battery Run Time
Up to 9 hours
10.1 cm x 0.935 cm x 19.17 cm
270 g
Nordics
Tablet
Operating System
Display
Resolution
1280 x 720
Touchscreen
Multi-Touch
Image Brightness
350 cd/m²
Glare, CineCrystal
MediaTek MT8735
1.3 GHz
Number of Cores
Quad-Core
64-bit Computing
Storage
16 GB eMMC
RAM
2 GB - LPDDR3 SDRAM
Max Supported Capacity
128 GB
Communications
Cellular Technology
4G
Cellular Protocols
LTE
Max Transfer Rate
150 Mbps
Rear Camera
Sensor Resolution
13 Megapixel
Front Camera
Sensor Resolution
2 Megapixel
Navigation System
Receiver
A-GPS/GPS/GLONASS
Multimedia
Audio
Two microphones, speaker
Expansion and Connectivity
Expansion Slots
1 x Micro-SIM card , 1 x Nano-SIM card
1 x Micro-USB
Lithium polymer
12.92 Wh
Run Time
Up to 9 hours
Run Time Details
Video playback: up to 9 hour(s)
Sensors
Ambient light sensor, proximity sensor, G-sensor
Power adapter
RoHS, WEEE
Nordics
10.1 cm
0.935 cm
19.17 cm
270 g
