Acer Iconia One 7 MediaTek MT8127 1GB 16GB eMMC 7" Android 5.0
Quicklinx: CPT0WS00 Mfr#: NT.LBKEK.001
  • Android 5.0 (Lollipop)
The Iconia One 7 is ready to travel the world. Its clean design was made to see and be seen. Its light, narrow case is easy to hold all day long. Its beautiful textured finish makes it easy to grab and go. It's always ready to capture and share your adventures.
  • Design to be seen
  • Visuals to delight
    The Iconia One 7 knows there's a difference between watching and experiencing. After immersing yourself in the exciting experience of its smooth Intel processor and sharp HD display with IPS technology, you'll never go back to only watching your world again.
  • Moments to be shared
    Your stories should have no limits. Keep your greatest moments close to you with the Iconia One 7's micro SD card slot, or easily share them with the world. Memories stay sharp when you can access them anywhere, anytime through AcerCloud.
  • Memories to capture
    Capture and share the memorable moments in life. Smile at the front camera as you take a selfie or share some laughs with a friend in a video chat. When you spot something amazing on one of your adventures, snap a photo with the rear camera and share it on a social network.
Acer ICONIA ONE 7 B1-770-K9Z5 - tablet - Android 5.0 (Lollipop) - 16 GB - 7"
Tablet
Operating System
Display
7" IPS TFT - LED backlight - 1024 x 600 - Multi-Touch
MediaTek MT8127 (Quad-Core)
Processor Clock Speed
1.3 GHz
Storage
16 GB eMMC
RAM
1 GB
Supported Flash Memory Cards
microSD, microSDHC
Wireless Connectivity
802.11b/g/n, Bluetooth 4.0
Rear Camera
2 Megapixel
Front Camera
0.3 Megapixel
Navigation System
GPS
Battery Run Time
Up to 5.5 hours
10.88 cm x 0.95 cm x 18.9 cm
280 g
White
United Kingdom
Tablet
Operating System
Display
Resolution
1024 x 600
Touchscreen
Multi-Touch
Image Aspect Ratio
16:10
Glare, CineCrystal
MediaTek MT8127
1.3 GHz
Number of Cores
Quad-Core
Storage
16 GB eMMC
RAM
1 GB - DDR3L SDRAM
microSD, microSDHC
Max Supported Capacity
32 GB
Communications
Rear Camera
Sensor Resolution
2 Megapixel
Still Image Resolutions
640 x 480, 1600 x 1200
Front Camera
Sensor Resolution
0.3 Megapixel
Navigation System
Receiver
GPS
Multimedia
Audio
Microphone, speaker
Expansion and Connectivity
Expansion Slots
1 x microSD
1 x Micro-USB , 1 x headphones
Lithium polymer
10.28 Wh
Run Time
Up to 5.5 hours
Run Time Details
Video playback: up to 5.5 hours
White
Sensors
G-sensor
Volume control
Power adapter
RoHS, WEEE
United Kingdom
10.88 cm
0.95 cm
18.9 cm
280 g
