Want a bigger tablet for the rest of us that's the full package? Start with a 10-inch HD display. Add enhanced audio, appealing software and some elegant design touches. Throw in convenient connectivity and what do you get? The Iconia One 10.
Fast performance
A powerful processor works with the performance-boosting features to make all your tablet actions fast and smooth. -
Smart, clutter-free design
The speakers and all cable ports are placed on the same edge. This means the speakers and all connected cables will always be out of your way when you hold the tablet horizontally. No more fumbling around cables and speakers with your hands!
- Acer ICONIA ONE 10 B3-A30-K6VW - tablet - Android 6.0 (Marshmallow) - 16 GB - 10.1"
- Product Type
- Tablet
- Operating System
- Display
- 10.1" IPS TFT - LED backlight - 1280 x 800 - Multi-Touch
- Processor
- MediaTek MT8163 (Quad-Core) - 64-bit
- Processor Clock Speed
- 1.3 GHz
- Storage
- 16 GB eMMC
- RAM
- 1 GB
- Supported Flash Memory Cards
- microSD, microSDXC
- Wireless Connectivity
- Bluetooth, 802.11a/b/g/n
- Rear Camera
- 5 Megapixel
- Front Camera
- 2 Megapixel
- Navigation System
- GPS
- USB host
- Battery Run Time
- Up to 10 hours
- 16.75 cm x 0.915 cm x 25.9 cm
- 538 g
- Black, rococo red
- Image Colour Disclaimer
- The displayed product image may be a different colour
- Localisation
- Nordics
- Product Type
- Tablet
- Operating System
Display
- Resolution
- 1280 x 800
- Touchscreen
- Multi-Touch
- Glare, CineCrystal, 10-point multi-touch, Mercury free, Wide Viewing Angle
- Processor
- MediaTek MT8163
- 1.3 GHz
- Number of Cores
- Quad-Core
- 64-bit Computing
- Storage
- 16 GB eMMC
- RAM
- 1 GB - DDR3L SDRAM
- Max Supported Capacity
- 128 GB
Communications
Rear Camera
- Sensor Resolution
- 5 Megapixel
Front Camera
- Sensor Resolution
- 2 Megapixel
Navigation System
- Receiver
- GPS
Multimedia
- Graphics
- Mali T720 MP2
- Audio
- Microphone, stereo speakers
Expansion and Connectivity
- Expansion Slots
- 1 x microSDXC
- 1 x Micro-USB , 1 x headphones mini jack (3.5mm)
- USB Host
- Voltage Required
- AC 120/230 V (50/60 Hz)
- Technology
- Lithium polymer
- Capacity
- 22.4 Wh
- Run Time
- Up to 10 hours
- Black, rococo red
- Case Material
- Anodised aluminium
- Sensors
- G-sensor
- Volume control, DTS HD Premium Sound
- Included Accessories
- Power adapter, tripod
- RoHS, WEEE
- Localisation
- Nordics
- 16.75 cm
- 0.915 cm
- 25.9 cm
- 538 g
