Acer H6510BD Full HD DLP Home Cinema Projector
PRICE DROP!
Clearance
Last Few Remaining
Price Drop
Quicklinx: 8R4MWS00 Mfr#: MR.JFZ11.002
Movies are massive at 300 inches (762 cm) and a billion colours. Action sequences are thrilling at an authentic 24p frame rate1 and with AcuMotion's blur control.1 With the superb clarity of available 1080p Full HD, you'll enjoy rich details, bright and natural colours, and exceptional contrast.
Easier
Position the picture just how you want it without moving the projector itself on models with lens shift control. Others let you choose among resolutions and aspect ratios or even among sources thanks to simultaneous connectivity. When you attach an image source, it's instantly found by Smart Detection.
More real
Movies gain depth and feeling with available 3D solutions that deliver stereoscopic visuals. Plus, those visuals are flicker free thanks to high refresh rates. Scenes and characters seem more real with keystone correction providing the perfect rectangular image. All models come with multiple connectors, including HDMI®, DVI and VGA.
More green
Enjoy your favourite movies again and again with no "burnout" thanks to Home Series projector bulbs, which in economy mode last up to 5,000 hours1 - that's more than two thousand films. Need an intermission? No eco-worries, as Acer EcoProjection technology reduces standby power consumption by up to 90%.
  • Clearer
    Movies are massive at 300 inches (762 cm) and a billion colors. Action sequences are thrilling at an authentic 24p frame rate and with AcuMotion's blur control. With the superb clarity of available 1080p Full HD, you'll enjoy rich details, bright and natural colors, and exceptional contrast.
  • Easier
    Position the picture just how you want it without moving the projector itself on models with lens shift control. Others let you choose among resolutions and aspect ratios or even among sources thanks to simultaneous connectivity. When you attach an image source, it's instantly found by smart detection.
  • More real
    Movies gain depth and feeling with available 3D solutions that deliver stereoscopic visuals. Plus, those visuals are flicker free thanks to high refresh rates. Scenes and characters seem more real with keystone correction providing the perfect rectangular image. The model comes with multiple connectors, including HDMI, DVI and VGA.
  • More green
    Enjoy your favorite movies again and again with no "burnout" thanks to Home Series projector bulbs, which in economy mode last up to 5000 hours - that's more than two thousand films. Need an intermission? No eco-worries, as Acer EcoProjection technology reduces standby power consumption by up to 90%.
Acer H6510BD - DLP projector - portable - 3D
DLP projector - 1080p
3D Capable
United Kingdom, Europe, EMEA
Brightness
3000 lumens
Contrast Ratio
10000:1 (dynamic)
Resolution
Full HD (1920 x 1080)
Native Aspect Ratio
16:9
Colour Support
1.07 billion colours
Bulb type
210 Watt
Bulb life cycle
Up to 4000 hour(s) - normal mode , Up to 5000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video (SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60, NTSC 3.58)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
AC 120/230 V
270 Watt
26.4 cm x 22 cm x 7.8 cm
2.2 kg
3D Capable
Projector
Brightness
3000 lumens
Brightness (Reduced)
2400 lumens
Contrast Ratio
10000:1 (dynamic)
Image Size
114.3 cm - 762 cm
Projection Distance
1.5 m - 7.6 m
Uniformity
85 %
Digital Zoom Factor
2x
Resolution
Full HD (1920 x 1080) (native) / 1920 x 1200 (resized)
Native Aspect Ratio
16:9
Colour Support
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
210 Watt
Bulb life cycle
ColorBoost Technology, 16:9 aspect ratio support, 4:3 aspect ratio support
Lens
Focus Type
Manual
Lens Aperture
F/2.59-2.87
Zoom Type
Manual
Zoom Factor
1.3x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, component video, composite video, S-Video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
2 Watt
Speakers
1 x mixed channel
1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 2 x HDMI - 19 pin HDMI Type A , 1 x USB - 4 pin mini-USB Type B , 1 x composite video input - RCA , 1 x audio line-in - mini-phone 3.5 mm , 1 x audio line-out - mini-phone 3.5 mm , 1 x S-video input - 4 pin mini-DIN , 1 x component video input - RCA x 3 , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x VGA output - 15 pin HD D-Sub (HD-15)
Carrying case, wireless remote control
1 x VGA cable
Security Features
Security Slot Type
Kensington security slot
AC 120/230 V
270 Watt
26.4 cm
22 cm
7.8 cm
2.2 kg
Limited warranty - 2 years - carry-in
