Acer H6502BD DLP 1080p HDMI 3D Home Cinema Projector
Quicklinx: CPZJWS00 Mfr#: MR.JN111.002
Equipped with an ambient light sensor, this projector can detect ambient lighting conditions and Acer LumiSense+ then dynamically optimizes the projected image's brightness levels and color saturation accordingly. In addition to image optimization based on ambient light, LumiSense+ has clever content-aware technology which also analyzes projected content frame by frame and dynamically adjusts image visibility to the optimal level.
  • Acer LumiSense
  • ColorBoost3D
    ColorBoost3D is a combination of three technical advancements, a 6-segment color wheel design and lamp power control capability, that improve the optical color performance while reducing color shifts and brightness decay, for both 2D and 3D visuals. The advanced technology provides brighter, more realistic images and color fidelity.
Acer H6502BD - DLP projector - portable - 3D
DLP projector - 1080p
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Speaker
Brightness
3400 lumens
Contrast Ratio
20000:1
Resolution
Full HD (1920 x 1080)
Native Aspect Ratio
16:9
Colour Support
1.07 billion colours
Bulb type
UHP 220 watt
Bulb life cycle
Up to 3500 hour(s) - normal mode , Up to 6500 hour(s) - economic mode
Video Input
RGB (NTSC, SECAM, PAL)
Speakers
Speaker(s) - integrated
368 watt
30.8 cm x 21.1 cm x 8.6 cm
2 kg
3D Capable
Built-in Devices
Speaker
Projector
Brightness
3400 lumens
Brightness (Reduced)
2560 lumens
Contrast Ratio
20000:1
Image Size
71 cm - 762 cm
Projection Distance
1 m - 9.9 m
Throw Ratio
1.49 - 1.64:1
Digital Zoom Factor
2x
Resolution
Full HD - Full HD (1920 x 1080) (native) / 1920 x 1200 (resized)
Native Aspect Ratio
16:9
Colour Support
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
UHP 220 watt
Bulb life cycle
Instant Pack Technology, SmartFormat Technology, EcoProjection Technology, 4:3 aspect ratio support, Acer ColorSafe II Technology, MHL compliance, ColorBoost 3D Technology, ExtremECO, Acer LumiSense+
Lens
Focus Type
Manual
Lens Aperture
F/2.56-2.68
Zoom Type
Manual
Zoom Factor
1.1x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
NTSC, SECAM, PAL
Analogue video Signal
RGB
Video Interfaces
VGA, HDMI, MHL
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
10 watt
Speakers
1 x mixed channel
1 x audio line-out - mini-phone stereo 3.5 mm , 1 x VGA input - 15 pin HD D-Sub (HD-15) , 2 x audio line-in - mini-phone stereo 3.5 mm , 2 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x USB - 4 pin mini-USB Type B (management) , 1 x serial RS-232
Carrying case, wireless remote control
Security Features
Security Slot Type
Kensington security slot
Power Source
AC
368 watt
30.8 cm
21.1 cm
8.6 cm
2 kg
Sound Emission
31 dBA
26 dBA
