The compact, chic-white Acer H5 series projector transforms your living room into a home theater via native 16:9 HD-ready projection, HDMI connectivity, brilliant color reproduction - and immersive stereoscopic 3D entertainment!
Perfect movie projection
Native 720p (HD-ready) resolution sharpens movie details; true 24p frame rate preserves real film quality; and high brightness and contrast ratio project crystal-clear images. Wall-color compensation lets you project accurate images even on colored walls, and HDMI connectivity portrays brilliant games and entertainment in the comfort of your living room. -
Immersive 3D visuals
Stereoscopic visuals add depth and feeling to games, movies and photographs. The H5 series projector is certified for leading 3D solutions. NVIDIA 3D Vision kits transform hundreds of PC games to full stereoscopic 3D, and DLP 3D ready kits with high refresh rates render a flicker-free 3D experience.
- Acer H5380BD - DLP projector - portable - 3D
- DLP projector - 720p
- 3D Capable
- Built-in Devices
- Speaker
- Brightness
- 3000 lumens
- Contrast Ratio
- 17000:1 (dynamic)
- Resolution
- 1280 x 720
- Native Aspect Ratio
- 16:9
- Colour Support
- 1.07 billion colours
- Bulb type
- 190 Watt
- Bulb life cycle
- Up to 5000 hours - normal mode , Up to 10000 hours - economic mode
- Video Input
- RGB, S-Video, composite video (NTSC, SECAM, PAL)
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V
- 31.4 cm x 22.3 cm x 9.3 cm
- 2.5 kg
- 2-year warranty
- 3D Capable
- Built-in Devices
- Speaker
Projector
- Brightness
- 3000 lumens
- Contrast Ratio
- 17000:1 (dynamic)
- Image Size
- 68.6 cm - 762 cm
- Projection Distance
- 1 m
- Digital Zoom Factor
- 2x
- Resolution
- 1280 x 720 (native) / 1920 x 1200 (resized)
- 16:9
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 100 kHz
- Bulb type
- 190 Watt
- Bulb life cycle
- ColorBoost II+ Technology, DLP 3D Ready, SmartFormat Technology, 16:9 aspect ratio support, EcoProjection Technology, 16:10 aspect ratio support, 4:3 aspect ratio support, Acer ColorSafe II Technology
Lens
- Lens Aperture
- F/2.5-2.67
- Zoom Type
- Manual
- Zoom Factor
- 1.1x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- NTSC, SECAM, PAL
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 2 Watt
- Speakers
- 1 x mixed channel
- 1 x composite video input - RCA , 2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-out - mini-phone 3.5 mm , 1 x HDMI - 19 pin HDMI Type A , 2 x audio line-in - mini-phone 3.5 mm , 1 x serial RS-232
- Included Accessories
- Carrying case, wireless remote control
- Cables Included
- 1 x VGA cable
- Voltage Required
- AC 120/230 V
- 31.4 cm
- 22.3 cm
- 9.3 cm
- 2.5 kg
- Limited warranty - 2 years - carry-in , Limited warranty - lamp - 1 year
- Sound Emission
- 31 dBA
- Sound Emission (Economic Mode)
- 28 dBA
