Acer H7 series monitor oozes style and quality. It delivers excellent detail, making it optimal for advanced HD productivity and multimedia applications.
Full HD LED monitor
This LED monitor delivers excellent detail, making it optimal for advanced HD productivity and multimedia applications. It also consumes less power and lasts longer. In addition, this monitor is mercury-free, making it safer for you and the environment. -
Acer TrueHarmony
Acer TrueHarmony presents a harmony of sound with enhanced bass, less distortion and dimensional sound in front of the listener. Its customized equalizer fine-tuning optimizes frequency balance ensuring movies come to life, songs have more depth, and games are even more engaging. -
Zero frame design
The zero-frame design maximizes its viewing area and provides a more seamless viewing experience for multi-monitor setups.
- Acer H277HU - LED monitor - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class B
- Energy Consumption per Year
- 57 kWh
- Power Consumption (On mode)
- 39 W
- USB 3.1 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 2560 x 1440 at 60 Hz
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1 / 100000000:1 (dynamic)
- Response Time
- 4 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 100% sRGB
- Input Connectors
- HDMI, DisplayPort
- Tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- White, silver
- 61.3 cm x 21.7 cm x 43.9 cm
- Environmental Standards
- ENERGY STAR Qualified
- MPR II
- 2-year warranty
- Display Type
- Energy Class
- Class B
- 57 kWh
- Diagonal Size
- 27"
- Built-in Devices
- USB 3.1 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 100% sRGB
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Acer EcoDisplay, Acer Adaptive Contrast Management (ACM), ComfyView, Zero Frame, Flicker-Less technology, Low Dimming technology, 6-axis colour adjustment, Blue Light Filter technology, Acer TrueHarmony, DTS Sound, 8-bit gamma
- White, silver
- 61.3 cm x 21.7 cm x 43.9 cm - with stand
Audio
- Speakers - stereo
- Output Power / Channel
- 3 Watt
- DisplayPort , HDMI , USB-C
Mechanical
- Tilt
- Tilt Angle
- -5/+15
- 1 USB 3.0 (powered), Acer Eyeprotect technology, 1 USB 3.1 charging port
- Cables Included
- 1 x DisplayPort cable , 1 x SuperSpeed USB-C cable
- MPR II
- Input Voltage
- 39 W
- Power Consumption (Typical)
- 55 Watt
- Power Consumption Sleep
- 0.5 Watt
- 0.5 Watt
- On / Off Switch
- No
- Dimensions & Weight Details
- With stand - width: 61.3 cm - depth: 21.7 cm - height: 43.9 cm , With stand - width: 61.3 cm - depth: 3.52 cm - height: 36.3 cm
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 2 years
