The Acer Nitro Radeon RX 7700 XT OC Edition redefines gaming with its impressive array of features designed for the avid gamer. At its core, the graphics card boasts a robust 12 GB of GDDR6 SDRAM, coupled with a high bandwidth of 432 GBps, ensuring smooth and detailed gaming visuals. The card's boost clock speed reaches up to 2600 MHz in OC mode, providing the power needed for demanding gaming and creative tasks.
Equipped with AMD's innovations, including FidelityFX Super Resolution for enhanced image quality and RDNA 3 Gaming Architecture for efficient performance, the Radeon RX 7700 XT is a powerhouse of gaming technology. It supports up to 4 monitors, allowing gamers to create expansive, immersive environments with resolutions up to 7680 x 4320. Whether you're battling in titles or creating in 3D rendering software, this video card delivers performance and quality.
Acer Nitro AMD Radeon RX 7700 XT OC 12G
Push the Boundaries -
Breakthrough AAA Gaming Performance
Step into the future with the Acer Nitro AMD Radeon RX 7700 XT OC graphics card, primed to bring today's and tomorrow's games to life at their utmost settings with 12GB of GDDR6 memory. Equipped with 54 unified AMD RDNA 3 compute units, it leverages cutting-edge AI technology and raytracing accelerators, promising a mesmerizing 1440p gaming journey. -
Dual Ringed Axial Fan Cooling
Featuring a distinct ringed design along the exterior of the fan housing, they're engineered to enhance airflow. A winglet along each blade further limits airflow leakage. The result is optimized heat dispersion for peak performance and smoother gameplay. -
Edit, Render, and Visualize with No Restraints
Experience blistering-fast content creation hardware, with accelerated rendering in applications supporting Radeon ProRender technology to bring photorealistic worlds to life. Whether it be professional video editing, graphic design, or 3D modelling, the possibilities are endless.
 - Acer Nitro Radeon RX 7700 XT - OC Edition - graphics card - Radeon RX 7700 XT - 12 GB
 - Graphics card
- Bus Type
 - PCI Express 4.0 x16
- Graphics Engine
 - AMD Radeon RX 7700 XT - up to
- Memory
 - 12 GB GDDR6
- Core Clock
 - 2280 MHz
- Boost Clock (OC)
 - 2600 MHz
- Memory Interface
 - 192-bit
- Max Resolution
 - 7680 x 4320
- Max Monitors Supported
 - 4
- Interfaces Details
 - HDMI , 3 x DisplayPort
- API Supported
 - DirectX 12 Ultimate, OpenGL 4.6
 - 5.02 cm x 28.1 cm x 12.97 cm
 - Graphics card
- Bus Type
- Graphics Engine
- Core Clock
 - 2280 MHz
- Boost Clock (OC)
 - 2600 MHz
- Max Resolution
 - 7680 x 4320
 - 4
- API Supported
 - Dual Fan Design, RDNA 3 Gaming Architecture, Radeon ProRender, AMD FidelityFX Super Resolution (FSR), AMD Smart Technologies, Axial-tech Fan Design
- Size
 - 12 GB
- Technology
 - GDDR6 SDRAM
- Bus Width
 - 192-bit
- Bandwidth
 - 432 GBps
- Required Power Supply
 - 750 W
- Additional Requirements
 - 2 x 8 pin PCI Express power connector
 - 5.02 cm
 - 28.1 cm
 - 12.97 cm
