Acer GN245HQbmid 23.6" Monitor - 2ms 16:9 LED 3D Full HD 1920x1080 inc NVIDIA 3D Glasses
Quicklinx: 7QV2WS00 Mfr#: ET.UG5HE.015
  • High-Definition Multimedia Interface (HDMI)
The Acer GD245HQ is perfectly suited to the successful Acer Aspire predator series: a line of desktops designed specifically to offer an outstanding gaming experience, with a body featuring original aggressive design containing all the next generation technologies the most expert gamers demand to get going on challenges of unmatched intensity. The 3D shutter eyeglasses with two lenses synchronized by the processor are an essential part of stereoscopic NVIDIA 3D Vision technology.
Every image is rendered twice, once for the right eye and once for the left, so that it is offset in relation to its 'double'. The GPU sends this information to the Acer GD245HQ, which works at a frequency of 120 Hz, and shows even-numbered frames to the left eye and odd-numbered frames to the right eye. All the 3D glasses do is synchronize with the monitor frame by opening and closing the right or left lens in synchronicity with it, so as to create the illusion of observing a stereoscopic scene with real depth, making the videogame into a true 3D environment. The glasses work via a special battery-powered infrared transmitter linked to the PC via USB port.
Package Contents
  • GN245HQbmid Widescreen LCD Monitor
  • Nvidia Glasses
  • Power Cable
  • Impressive design
    The chic bezel and aviation-inspired base present a polished look that's eye-catching as a desktop PC complement or secondary notebook display.
  • Brilliant display
    The superior resolution, fast response time, and high contrast ratio provide extra-fine details and smooth movement for your favorite entertainment. The 16:9 aspect ratio frames movies and HDTV content perfectly.
  • Straightforward functionality
    Just press the input key on the main menu and the G Series automatically searches signals across its VGA, DVI and HDMI (High-Definition Multimedia Interface) ports.
Acer GN245HQbmid - LED monitor - Full HD (1080p) - 23.6" - with NVIDIA 3D Vision kit
LED-backlit LCD monitor - 23.6"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 120 Hz
Brightness
300 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
2 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
57.5 cm x 19.4 cm x 41.8 cm
5 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
MPR II, TUV GS, RoHS, ISO 9241-307
Bundled with
Display Type
Diagonal Size
23.6"
3D Technology
Alternate-frame sequencing
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
2 ms
Horizontal Viewing Angle
176
Vertical Viewing Angle
176
Backlight Technology
LED backlight
HDCP, 3D Vision-Ready (120Hz), Acer Adaptive Contrast Management (ACM)
5 kg
Bundled with
Audio
Speakers - stereo - integrated
VGA , DVI-D (dual link) , HDMI
Mechanical
Tilt
Tilt Angle
20
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), wall mountable
Power Consumption (Typical)
38.2 Watt
Power Consumption Stand by / Sleep
1.85 Watt
Sustainability Information
ENERGY STAR Certified
Limited warranty - 2 years - carry-in
