The Acer GD245HQ is perfectly suited to the successful Acer Aspire predator series: a line of desktops designed specifically to offer an outstanding gaming experience, with a body featuring original aggressive design containing all the next generation technologies the most expert gamers demand to get going on challenges of unmatched intensity. The 3D shutter eyeglasses with two lenses synchronized by the processor are an essential part of stereoscopic NVIDIA 3D Vision technology.
Every image is rendered twice, once for the right eye and once for the left, so that it is offset in relation to its 'double'. The GPU sends this information to the Acer GD245HQ, which works at a frequency of 120 Hz, and shows even-numbered frames to the left eye and odd-numbered frames to the right eye. All the 3D glasses do is synchronize with the monitor frame by opening and closing the right or left lens in synchronicity with it, so as to create the illusion of observing a stereoscopic scene with real depth, making the videogame into a true 3D environment. The glasses work via a special battery-powered infrared transmitter linked to the PC via USB port.
Package Contents
- GN245HQbmid Widescreen LCD Monitor
- Nvidia Glasses
- Power Cable
Impressive design
The chic bezel and aviation-inspired base present a polished look that's eye-catching as a desktop PC complement or secondary notebook display. -
Brilliant display
The superior resolution, fast response time, and high contrast ratio provide extra-fine details and smooth movement for your favorite entertainment. The 16:9 aspect ratio frames movies and HDTV content perfectly. -
Straightforward functionality
Just press the input key on the main menu and the G Series automatically searches signals across its VGA, DVI and HDMI (High-Definition Multimedia Interface) ports.
- Acer GN245HQbmid - LED monitor - Full HD (1080p) - 23.6" - with NVIDIA 3D Vision kit
- LED-backlit LCD monitor - 23.6"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 120 Hz
- Brightness
- 300 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 2 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, DVI-D, VGA
- Speakers
- Integrated
- Tilt
- Black
- 57.5 cm x 19.4 cm x 41.8 cm
- 5 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- MPR II, TUV GS, RoHS, ISO 9241-307
- 2-year warranty
- Bundled with
- NVIDIA 3D Vision kit
- Display Type
- Diagonal Size
- 23.6"
- 3D Technology
- Alternate-frame sequencing
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 2 ms
- Horizontal Viewing Angle
- 176
- Vertical Viewing Angle
- 176
- Backlight Technology
- LED backlight
- HDCP, 3D Vision-Ready (120Hz), Acer Adaptive Contrast Management (ACM)
- Black
- 5 kg
- Bundled with
Audio
- Speakers - stereo - integrated
- VGA , DVI-D (dual link) , HDMI
Mechanical
- Tilt
- Tilt Angle
- 20
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), wall mountable
- Power Consumption (Typical)
- 38.2 Watt
- Power Consumption Stand by / Sleep
- 1.85 Watt
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 2 years - carry-in
