Keep cool as you fly through the hot parts of the galaxy with advanced thermal technology. And with Killer DoubleShot Pro technology, you choose which applications get to use your precious bandwidth. Even more importantly, you can split your Internet requirements over wired and wireless connections simultaneously.
Keep cool
Keep cool as you fly through the hot parts of the galaxy with advanced thermal technology. -
Kill lag
With Killer DoubleShot Pro technology, you choose which applications get to use your precious bandwidth. Even more importantly, you can split your Internet requirements over wired and wireless connections simultaneously. -
Predator DustDefender
Keep your rig clean and ensure crucial components run smoothly with Predator DustDefender. Alternating airflow directions and an ultra-thin, all-metal fan with advanced aerodynamics, help stop dust from building up. -
Front and back design
Hard angles and aggressive accents were inspired by galactic battle cruisers. Architecturally designed air exhaust vents ensure a bold look from any angle. -
Predator ProZone
The keyboard has customizable backlight zones, with many colors to choose from, and programmable macro profiles you can share. A number pad and dedicated macro buttons give you the control you deserve. -
SoundPound technology
Predator SoundPound boasts four speakers, two subwoofers and advanced audio for deep sound immersion.
- Acer Predator 17 G9-793-79RR - 17.3" - Intel Core i7 - 6700HQ - 16 GB RAM - 128 GB SSD + 1 TB HDD - UK
- Product Type
- Notebook
- Operating System
- Win 10 Home 64-bit
- Processor
- Intel Core i7 (6th Gen) - 6700HQ / 2.6 GHz, up to 3.5 GHz / 6 MB Cache
- Memory
- 16 GB DDR4 (2 x 8 GB)
- Storage
- 128 GB SSD + 1 TB HDD / 5400 rpm
- Optical Drive
- DVD SuperMulti
- Display
- 17.3" LED backlight 1920 x 1080 / Full HD
- Graphics
- NVIDIA GeForce GTX 1070
- Video Memory
- 8 GB GDDR5 SDRAM
- Keyboard
- UK
- Keyboard Backlight
- Yes (RGB)
- Numeric Keypad
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet
- Battery
- 8-cell - up to 3 hours
- Black
- 42.3 cm x 32.15 cm x 3.97 cm
- 4.35 kg
- Localisation
- Region: United Kingdom
- Environmental Standards
- - EPEAT Climate+
- Product Type
- Notebook
- Operating System
- Windows 10 Home 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i7 (6th Gen) 6700HQ / 2.6 GHz
- Max Turbo Speed
- 3.5 GHz
- Number of Cores
- Quad-Core
- Cache
- 6 MB
- 64-bit Computing
- Chipset
- Mobile Intel HM170
- Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 16 GB (2 x 8 GB)
- Max RAM Supported
- 64 GB
- Technology
- DDR4 SDRAM
- Speed
- 2133 MHz / PC4-17000
- Rated Speed
- 2133 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 4
- Empty Slots
- 2
Storage
- Main Storage
- 128 GB SSD M.2 2280 SATA 6Gb/s
- Secondary Storage
- 1 TB HDD SATA 3Gb/s / 5400 rpm
- Optical Drive
- DVD±RW (±R DL) / DVD-RAM - tray
Display
- 17.3" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 300 cd/m²
- Anti-glare
Audio & Video
- Graphics Processor
- Video Memory
- 8 GB GDDR5 SDRAM
- Camera
- Yes - 1280 x 720
- Camera Features
- 720p HD movie recording
- Sound
- Four speakers, subwoofer, two microphones
- Dolby Audio Premium
- Audio Features
- Output: Acer TrueHarmony Plus technology
Input
- Keyboard, touchpad
- Yes (RGB)
- Keyboard Layout
- UK
- Numeric Keypad
- Multi-gesture touch pad, Acer FineTip keyboard, precision touchpad, Backlit touchpad
Communications
- Wireless
- Wireless Controller
- Killer Wireless-AC 1535 - M.2 Card
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Killer Ethernet E2400
- Wake-on-LAN (WOL), Killer DoubleShot Pro Technology
- Technology
- 8-cell Lithium Ion
- Capacity
- 6000 mAh
- Run Time
- Up to 3 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 230 Watt, 19.5 V
Connections & Expansion
- Interfaces Details
- HDMI , DisplayPort , USB-C , 4 x USB 3.0 , LAN , Headphone/microphone combo jack , Microphone input
- Memory Card Reader
- Yes (SD Card)
- Black
- Administrator password, system password, hard drive password, MU-MIMO technology
- Theft/Intrusion Protection
- Included Accessories
- Power adapter, Cooler Master swappable fan module
- ACPI 5.0
- Localization
- 4.35 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
