Acer G7 Series monitors give you the outstanding visuals you want and the value you need. With a Zero Frame design and multiple color options, these stylish monitors fit perfectly in your home or office. Visuals are sharp and vivid on G7 Series monitors, thanks to Full HD resolution and IPS technology.
The futuristic style of the G7 Series incorporates a slim Zero Frame design that saves space on your desk and lets you place multiple G7 monitors side by side to build a seamless big-screen display. You can pick the color that fits your style and you can tilt the display from -5 to 15 degrees, for comfortable viewing.
Images on the G7 Series come to life thanks to IPS technology with deeper black levels, crisper whites and stronger colors, even when viewed from wide angles.
Acer CrystalBrite technology on the G7 Series offers greater color intensity. You'll enjoy tasks and entertainment more, thanks to the finer details delivered by Full HD resolution.
Beauty from all angles
Acer G7 Series monitors give you the outstanding visuals you want and the value you need. With a Zero Frame design and multiple color options, these stylish monitors fit perfectly in your home or office. Visuals are sharp and vivid on G7 Series monitors, thanks to Full HD resolution and IPS technology. -
Slim and elegant
The futuristic style of the G7 Series incorporates a slim Zero Frame design that saves space on your desk and lets you place multiple G7 monitors side by side to build a seamless big-screen display. You can pick the color that fits your style and you can tilt the display from -5 to 15 degrees, for comfortable viewing. -
Expansive views
Images on the G7 Series come to life thanks to IPS technology with deeper black levels, crisper whites and stronger colors, even when viewed from wide angles. -
Vivid color
Acer CrystalBrite technology on the G7 Series offers greater color intensity. You'll enjoy tasks and entertainment more, thanks to the finer details delivered by Full HD resolution. -
Green perspective
The G7 Series monitors are RoHS compliant and mercury free. Plus, advanced Acer EcoDisplay technologies and white LED backlighting save power to cut your costs and conserve the planet's resources. Acer also uses recyclable packaging, further reducing ecological impact.
- Acer G277HL - LED monitor - Full HD (1080p) - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class A
- Energy Consumption per Year
- 39 kWh
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.311 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 6 ms
- Colour Support
- 16.7 million colours
- Colour Gamut
- 70% NTSC
- Input Connectors
- HDMI, DVI, VGA
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 62.2 cm x 20.3 cm x 45.5 cm
- Environmental Standards
- ENERGY STAR Qualified
- MPR II
- 2-year warranty
- Display Type
- Energy Class
- Class A
- 39 kWh
- Diagonal Size
- 27"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.311 mm
- Pixel Per Inch
- 82
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 70% NTSC
- Response Time
- 6 ms
- Vertical Refresh Rate
- 55 - 75 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Tilt
- HDCP, Acer EcoDisplay, Acer Adaptive Contrast Management (ACM), Zero Frame, Mercury free
- Black
- 62.2 cm x 20.3 cm x 45.5 cm - with stand
- VGA , DVI (HDCP) , HDMI
Mechanical
- Tilt Angle
- -5/+15
- Included Accessories
- Stand
- Cables Included
- 1 x VGA cable
- MTBF
- 30,000 hour(s)
- MPR II
- Power Supply
- External
- Input Voltage
- Power Consumption (Typical)
- 26 Watt
- Power Consumption Stand by
- 450 mW
- Power Consumption Sleep
- 400 mW
- Dimensions & Weight Details
- With stand - width: 62.2 cm - depth: 20.3 cm - height: 45.5 cm , Without stand - width: 62.2 cm - depth: 3.4 cm - height: 36.8 cm
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 2 years
