Acer Extensa M2710 MT i5-6400 8GB 1TB HDD Windows 10 Pro 64-bit
Quicklinx: D6MDWS00 Mfr#: DT.X0TEK.007
  • Core i5
Acer Extensa EM2 series is built around companies' demands for reliable, easy to manage, expandable and thoroughly secure machines with a cost-effective design.
  • Essential productivity
    Presenting dual monitor support, Extensa EM2 series doubles available viewing space and makes it easier to work with multiple applications and documents at the same time.
  • Easy manageability and security
    Valuable utilities conceived to simplify manageability and enhance security help companies to protect their assets from unauthorized access or data losses.
  • Energy efficiency
    All components within these desktops are free of hazardous substances, so they have a smaller footprint while helping to drive business success.
Acer Extensa M2710_E - MT - Core i5 6400 2.7 GHz - 8 GB - HDD 1 TB
Personal computer - mini tower
Region: United Kingdom
Intel Core i5 (6th Gen) 6400 / 2.7 GHz (, up to 3.3 GHz, (Quad-Core)
Processor Socket
LGA1151 Socket
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
6 MB
Cache Per Processor
6 MB
RAM
8 GB (installed) / 16 GB (max) - DDR4 SDRAM
Storage Controller
SATA
Hard Drive
HDD 1 TB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD-Writer
Graphics Controller
Intel HD Graphics 530
1GbE
AC 120/230 V
OS Provided
Windows 10 Pro 64-bit Edition
17.5 cm x 37.2 cm x 36.5 cm
6 kg
Personal computer
Product Form Factor
Mini tower
Processor / Chipset
CPU
Clock Speed
2.7 GHz
Max Turbo Speed
3.3 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Socket
LGA1151 Socket
Chipset Type
Intel H110 Express
Cache Memory
Installed Size
6 MB
Cache Per Processor
6 MB
RAM
Installed Size
8 GB / 16 GB (max)
DDR4 SDRAM
Effective Memory Speed
2133 MHz
Rated Memory Speed
2400 MHz
DIMM 288-pin
Unbuffered
Configuration Features
1 x 8 GB
Hard Drive
HDD
1 x 1 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Optical Storage
DVD-Writer - SATA
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
VGA, DVI
Input Device
Mouse, keyboard
Keyboard
USB
Mouse
USB
Ethernet Controller
Realtek RTL8111E
Bays
5.25" , 3.5"
Slots
DIMM 288-pin , 1 (total) / 0 (free) x CPU , 1 PCIe x16 , 1 PCIe x1 , 1 M.2 Card
4 x USB 2.0 , 2 x USB 3.0 , 1 x audio line-out , 1 x audio line-in , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x DVI
Theft/Intrusion Protection
BSMI, CB, FCC, RoHS, PC 2001, EuP
Power supply
AC 120/230 V
Power Provided
220 Watt
Efficiency
82%+
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
17.5 cm
37.2 cm
36.5 cm
6 kg
