Designed for businesspeople who need everyday computing power and functionality, Extensa 15 laptops have everything you need for a comfortable day's work with a long battery life. These thin, light laptops deliver outstanding productivity while providing a full range of essential business functions.
Responsive Performance
Get your jobs done quickly and efficiently while multitasking with ease thanks to the powerful AMD Ryzen processor, AMD Radeon Vega graphics, and up to 12GB of DDR4 memory. -
Stunning Visuals
View fine details and rich colors on the 15.6" FHD IPS display with narrow bezels for a higher screen-to-body ratio. Not only that, comfortably view your screen in various settings with ComfyView technology, which reduces glare by limiting reflected light. -
Enhanced Video Conferencing
Working remotely or from home has never been easier. Maintain a strong, consistent wireless signal with the strategically placed Wi-Fi 5 (802.11ac) wireless antenna and MU-MIMO. The optimized digital webcam, microphone, and two built-in stereo speakers keep you connected with amazing audio and visual clarity. -
Refined Design
The Extensa 15's stylish chassis has been redesigned to be thinner and lighter than ever. At less than 20mm thin and a starting weight of under 1.9kg, it can accompany you wherever you need to go, and with a battery life of up to 9 hours, it has enough power to last you through the day. -
Faster Storage
Enjoy blazingly fast performance with up to 1TB PCIe NVMe SSD. Everything's accelerated, from booting up to everyday computing and opening media-rich files. -
Ports for All Occasions
Connecting to peripherals is streamlined and simple with the maximum amount of options. Accomplish more with a full range of ports, including one USB2.0, two USB3.2 Gen1, HDMI and more.
- Acer Extensa 15 EX215-52-324T - 15.6" - Intel Core i3 - 1005G1 - 4 GB RAM - 128 GB SSD - UK
- Product Type
- Notebook
- Operating System
- Win 10 Home 64-bit
- Processor
- Intel Core i3 (10th Gen) - 1005G1 / 1.2 GHz, up to 3.4 GHz / 4 MB Cache
- Memory
- 4 GB DDR4 (provided memory is soldered)
- Storage
- 128 GB SSD
- Display
- 15.6" LED backlight 1920 x 1080 / Full HD
- Graphics
- Intel UHD Graphics
- Keyboard
- UK
- Numeric Keypad
- Integrated Webcam
- Networking
- Bluetooth, 802.11a/b/g/n/ac, Gigabit Ethernet
- Battery
- 2-cell - up to 9 hours
- Shale black
- 36.34 cm x 25.05 cm x 1.99 cm
- 1.9 kg
- Localisation
- Region: United Kingdom
- Limited warranty - 1 year - carry-in , International travellers warranty - 1 year
- Product Type
- Notebook
- Operating System
- Windows 10 Home 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i3 (10th Gen) 1005G1 / 1.2 GHz
- Max Turbo Speed
- 3.4 GHz
- Number of Cores
- Dual-Core
- Cache
- 4 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 4 GB (provided memory is soldered)
- Max RAM Supported
- 12 GB
- Technology
- DDR4 SDRAM
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 1
- Empty Slots
- 1
Storage
- Main Storage
- 128 GB SSD - Kingston
Display
- 15.6"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 220 cd/m²
- Anti-glare, ComfyView, 8 ms response rate, Narrow Border Display
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - VGA
- Resolution
- 0.3 Megapixel
- Sound
- Stereo speakers, microphone
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
- Numeric Keypad
- Multi-gesture touch pad, Acer FineTip keyboard, precision touchpad
Communications
- Wireless
- Network Interface
- Gigabit Ethernet
- Wake-on-LAN (WOL)
- Technology
- 2-cell Lithium Ion
- Capacity
- 36 Wh
- Run Time
- Up to 9 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19 V
Connections & Expansion
- Interfaces Details
- HDMI , USB 3.2 Gen 1 , 2 x USB 2.0 , LAN , Headphone/microphone combo jack
- Shale black
- Case Material
- Polycarbonate, ABS plastic
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- Localization
- 1.9 kg
- Shipping Dimensions (WxDxH) / Weight
- 49.8 cm x 6.5 cm x 31 cm / 2.85 kg
Sustainability Information
- TCO Certified
APC BACK-UPS BE650G2-UK 650VA 230V | In Stock | £104.94 |
APC BACK-UPS BE850G2-UK 850VA 230V USB | In Stock | £119.10 |
