All for 4K
Once you've sat with a 4k screen, you'll never settle for less. With 4k you can see more, do more and enjoy beyond measure. -
Impress with IPS
An IPS panel lets you view your monitor clearly at angles of up to 178° while maintaining the same level of high-quality color. -
Speakers at the ready
Two speakers, directly built in to your monitor, save on desk space while still offering up a powerful listening experience. -
Stand strong
Two thin, strong metal feet grace the bottom of the ET430K, holding the colossal screen aloft for all to admire. -
True clarity in vivid colors
Color-enhancing, image-sharpening and eyecare technologies combine flawlessly in the ET430K display's 4k resolution. -
Color depth in 10 Bit
To create images that appear smooth and realistic, a high color depth is needed. With the ET430K monitor, you have that. -
AcerVisionCare
AcerVisionCare incorporates several technologies to reduce eye strain and provide a more comfortable viewing experience.
- Acer ET430K - LED monitor - 4K - 43"
- LED-backlit LCD monitor - 43"
- Energy Class
- Class A
- Energy Consumption per Year
- 100 kWh
- Power Consumption (On mode)
- 69 W
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 4K 3840 x 2160 at 60 Hz
- Pixel Pitch
- 0.2451 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 1.07 billion colours
- Colour Gamut
- 72% NTSC
- Input Connectors
- 2xHDMI, DisplayPort, Mini DisplayPort
- Tilt
- Voltage
- AC 120/230 V
- White
- 96.6 cm x 24.3 cm x 65.3 cm
- 12.36 kg
- MPR II
- 2-year warranty
- Display Type
- Energy Class
- Class A
- 100 kWh
- Diagonal Size
- 43"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2451 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72% NTSC
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- ComfyView, Flicker-Less technology, Low Dimming technology, 6-axis colour adjustment, Super Sharpness technology, Acer VisionCare, Wide Viewing Angle, Acer BluelightShield technology, 72% NTSC colour gamut
- White
- 12.36 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 7 Watt
- 2 x HDMI , DisplayPort output , DisplayPort , Mini DisplayPort , Audio line-out
Mechanical
- Tilt
- Tilt Angle
- -3.5/+11.5
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x DisplayPort cable , 1 x HDMI cable
- MPR II
- Input Voltage
- AC 120/230 V
- 69 W
- Power Consumption (Typical)
- 55 Watt
- Power Consumption Stand by
- 0.45 Watt
- 0.35 Watt
- Limited warranty - 2 years
- 5 °C
- 35 °C
- 10 - 85% (non-condensing)
