A stylishly curved Full HD display not only looks good but increases user visibility. A combination of technologies is used to provide users with a great viewing experience. Crisp, true-to-life colors come alive in Full HD 1080p resolution.
Elegant and Functional Design
A stylishly curved Full-HD display not only looks good but increases user visibility. -
Delivering Great Imaging Technology
A combination of technologies is used to provide users with a great viewing experience. -
Full HD Resolution
Crisp, true-to-life colours come alive in Full HD 1080p resolution. -
ZeroFrame
Improved enjoyment and maximum visibility of the screen with the frameless design. -
Stand Strong
Two thin, strong metal feet grace the bottom of the ET2, holding the impressive 31.5" screen aloft for all to admire. -
Care for Your Vision
Acer VisionCare incorporates several technologies to reduce eye strain and provide a more comfortable viewing experience. -
Professional Color Adjustment
For professional editing, achieve true-life accuracy with 6-Axis Color Adjustment. -
Wide Angle Display
Share what's on your screen with friends and family as colors stay true no matter what angle you're viewing from.
- Acer ET322QK - LED monitor - 4K - 31.5"
- LED-backlit LCD monitor - 31.5"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/429430
- Energy Class
- Class G
- Energy Consumption per Year
- 63 kWh
- Power Consumption (On mode)
- 40.5 W
- Adaptive-Sync Technology
- AMD FreeSync
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- 4K 3840 x 2160 at 60 Hz
- Brightness
- 300 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 4 ms
- Colour Support
- 1.07 billion colours
- Input Connectors
- 2xHDMI, DisplayPort
- Tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- White
- Dimensions (WxDxH) - without stand
- 73 cm x 24.7 cm x 52.9 cm
- 5.62 kg
- Localisation
- Russia
- MPR II, Directive 1275/2008, EN 50564:2011, EN 50581:2012, RoHS 2011/65/EU, EN 55024:2010, ErP 2009/125/EC, EMC 2014/30/EU, LVD 2014/35/EU, EN 55032:2012+AC:2013 Class B, EN 6100-3-3:2013, EN 61000-3-2:2014 Class D, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
- Display Type
- Energy Class
- Class G
- Energy Class (HDR)
- Class G
- 63 kWh
- Diagonal Size
- 31.5"
- AMD FreeSync
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 4 ms
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Acer Adaptive Contrast Management (ACM), ComfyView
- White
- 73 cm x 24.7 cm x 52.9 cm - without stand
- 5.62 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 4 Watt
- 2 x HDMI , DisplayPort , Audio line-out
Mechanical
- Tilt
- Tilt Angle
- -3.5/+11.5
- VESA interface support
- Cables Included
- 1 x DisplayPort cable
- Localisation
- Russia
- Input Voltage
- 40.5 W
- Power Consumption SDR (On mode)
- 40.5 kWh/1000h
- Power Consumption HDR (On mode)
- 135.9 kWh/1000h
- Power Consumption Stand by
- 0.45 Watt
- 0.34 Watt
