Acer ET322QK 31.5" 3840x2160 4ms HDMI DP VGA LED Monitor
Quicklinx: DPQFWS00 Mfr#: UM.JE2EE.013
A stylishly curved Full HD display not only looks good but increases user visibility. A combination of technologies is used to provide users with a great viewing experience. Crisp, true-to-life colors come alive in Full HD 1080p resolution.
  • Elegant and Functional Design
    A stylishly curved Full-HD display not only looks good but increases user visibility.
  • Delivering Great Imaging Technology
  • Full HD Resolution
    Crisp, true-to-life colours come alive in Full HD 1080p resolution.
  • ZeroFrame
    Improved enjoyment and maximum visibility of the screen with the frameless design.
  • Stand Strong
    Two thin, strong metal feet grace the bottom of the ET2, holding the impressive 31.5" screen aloft for all to admire.
  • Care for Your Vision
    Acer VisionCare incorporates several technologies to reduce eye strain and provide a more comfortable viewing experience.
  • Professional Color Adjustment
    For professional editing, achieve true-life accuracy with 6-Axis Color Adjustment.
  • Wide Angle Display
    Share what's on your screen with friends and family as colors stay true no matter what angle you're viewing from.
Acer ET322QK - LED monitor - 4K - 31.5"
LED-backlit LCD monitor - 31.5"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/429430
Energy Class
Class G
Energy Consumption per Year
63 kWh
Power Consumption (On mode)
40.5 W
Adaptive-Sync Technology
AMD FreeSync
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Brightness
300 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
4 ms
Colour Support
1.07 billion colours
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
White
73 cm x 24.7 cm x 52.9 cm
5.62 kg
Russia
MPR II, Directive 1275/2008, EN 50564:2011, EN 50581:2012, RoHS 2011/65/EU, EN 55024:2010, ErP 2009/125/EC, EMC 2014/30/EU, LVD 2014/35/EU, EN 55032:2012+AC:2013 Class B, EN 6100-3-3:2013, EN 61000-3-2:2014 Class D, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
Display Type
Energy Class
Class G
Energy Class (HDR)
Class G
63 kWh
Diagonal Size
31.5"
AMD FreeSync
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Acer Adaptive Contrast Management (ACM), ComfyView
White
73 cm x 24.7 cm x 52.9 cm - without stand
5.62 kg
Audio
Speakers - stereo
Output Power / Channel
4 Watt
2 x HDMI , DisplayPort , Audio line-out
Mechanical
Tilt
Tilt Angle
-3.5/+11.5
VESA interface support
1 x DisplayPort cable
Russia
Input Voltage
40.5 W
40.5 kWh/1000h
Power Consumption HDR (On mode)
135.9 kWh/1000h
Power Consumption Stand by
0.45 Watt
Power Consumption (Off Mode)
0.34 Watt
