Acer ET271 27" 1920x1080 4ms VGA HDMI LED Monitor
Quicklinx: DB08WS00 Mfr#: UM.HE1EE.001
Select:
  • 27"
BlueLightShield technology reduces the exposure of blue light, which can be potentially harmful, by adjusting color hue and brightness. You can access and select different filter settings on-screen easily through the OSD menu to find the optimal one, that suits the task at hand.
  • Flickerless technology
    Flickerless technology eliminates screen flickering by providing a stable supply of power to the display. This minimizes instances of eyestrain and other potentially damaging eye ailments, when you're embroiled in long, drawn-out gaming sessions.
  • ComfyView display
    ComfyView technology reduces the amount of light, being reflected on your display, for more comfortable viewing in various settings.
  • Wide viewing angle
    Wide viewing angle signage is able to be viewed from 178 and still preserve image clarity and prime colors.
  • 6-axis color adjustments
    For professional editing, achieve true-life accuracy with 6-axis color adjustment. You will also enjoy perfect color game play as it makes your multiple screens the same color.
Acer ET271 - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A
Energy Consumption per Year
37 kWh
Power Consumption (On mode)
26 W
Aspect Ratio
16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
4 ms
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
AC 120/230 V
Denmark, Finland, Norway, Sweden
MPR II, DDC-2B, FCC Part 15, DDC/CI, DDC, WEEE, EN 50564:2011, EN 50581:2012, Directive 1275/2008/EC, RoHS 2011/65/EU, EN 61000-3-3:2013, EN 55024:2010, ErP 2009/125/EC, EMC 2014/30/EU, LVD 2014/35/EU, EN 55032:2012+AC:2013 Class B, EN 61000-3-2:2014 Class D, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
Display Type
Energy Class
Class A
37 kWh
Diagonal Size
27"
Aspect Ratio
16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
Response Time
4 ms
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Eco-Mode, Acer Adaptive Contrast Management (ACM), blue light reduction, Acer Empowering Technology, 6-axis colour adjustment, Transition Minimised Differential Signaling (TMDS) technology, Colour Temperature Selection, Movie Mode, 6-axis Hue, 6-axis Saturate
VGA , HDMI
Mechanical
Tilt
Tilt Angle
-5/+20
LED indicator
1 x VGA cable - VGA to VGA
Input Voltage
AC 120/230 V
26 W
On / Off Switch
No
