Thin, Light, and Solid
Weighing a mere 1.985kg and measuring just 24.85mm high, this laptop is the thinnest and lightest 14" IP53-rated rugged laptop designed for mobile professionals who want to maintain a stylish and modern look. -
Impact Resistant
This rugged laptop has been constructed using shock-absorbent materials including a honeycomb shell and is engineered to withstand drops, falls, and water. The shock absorbent corners and reinforced design protects the hard drive and has been independently certified to meet MIL-STD 810G impact resistance. -
Spill Resistant
Designed to be used in wet conditions, this laptop's components are protected by IP53 level certification. The display is covered with Corning Gorilla Glass to protect against water along all edges. The I/O ports are further sealed against ingress while the keyboard features drainage holes to remain dry. -
Strong on Security
Strong security is serious business, and this model comes with the best. The hardware-level Trusted Platform Module (TPM) 2.0 is a powerful anti-tampering chip that checks for signs of intrusion during system boot up. For further security, this model includes fingerprint login, Windows Hello, and other additional Windows 10 security features. -
All-day Battery
With a long life battery, there's no concern about power being lost during critical actions. This battery will keep users working for up to 13 hours. -
Performance You Demand
In today's modern workplace, you need a laptop with the power to get things done. Boasting an up to 10th Gen Intel Core i7 processor, an optional NVIDIA MX230 discrete graphics chip, up to 32GB DDR4 memory, up to 1TB of HDD storage, and an optional up to 512GB PCIe Gen3 NVMe SSD, you can easily work in confidence no matter where you are.
- Acer Enduro N3 EN314-51W - 14" - Intel Core i7 - 10510U - 16 GB RAM - 512 GB SSD
- Product Type
- Notebook - rugged
- Operating System
- Win 10 Pro 64-bit
- Processor
- Intel Core i7 (10th Gen) - 10510U / 1.8 GHz, up to 4.9 GHz / 8 MB Cache
- Memory
- 16 GB DDR4 (1 x 16 GB)
- Storage
- 512 GB SSD - NVMe
- Display
- 14" LED backlight 1920 x 1080 / Full HD
- Graphics
- Intel UHD Graphics
- Keyboard Backlight
- Integrated Webcam
- Networking
- Bluetooth 5.0, 802.11a/b/g/n/ac Wave 2/ax, Gigabit Ethernet
- Battery
- 4-cell - up to 13 hours
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
- Shale black
- 35.1 cm x 24.7 cm x 2.485 cm
- 1.98 kg
- Localisation
- Region: United Kingdom
- Specific Absorption Rate (SAR)
- 0.96 W/kg (head) , 0.96 W/kg (body) , 0.96 W/kg (limb)
- Limited warranty - 3 years - carry-in , International travellers warranty - 1 year
- Product Type
- Notebook - rugged
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i7 (10th Gen) 10510U / 1.8 GHz
- Max Turbo Speed
- 4.9 GHz
- Number of Cores
- Quad-Core
- Cache
- 8 MB
- Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 16 GB (1 x 16 GB)
- Technology
- DDR4 SDRAM
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 512 GB SSD PCIe - NVM Express (NVMe)
Display
- 14" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 250 cd/m²
- Corning Gorilla glass, anti-glare, 25 ms response rate, Narrow Border Display
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - HD
- Camera Features
- Windows Hello
- Sound
- Stereo speakers, microphone
Input
- Keyboard, touchpad
- Multi-gesture touch pad, spill-resistant, Acer FineTip keyboard
Communications
- Wireless
- Wireless Controller
- Intel Wi-Fi 6 AX 201 - M.2 2230
- Network Interface
- Gigabit Ethernet
- Wake-on-LAN (WOL)
- Technology
- 4-cell Lithium Ion
- Capacity
- 48 Wh
- Run Time
- Up to 13 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt
Connections & Expansion
- Interfaces Details
- HDMI , VGA , USB-C 3.2 Gen 1 (supports DisplayPort Alt Mode) (DC-In combo) , USB 3.2 Gen 1 , USB 2.0 , LAN , Headphone/microphone combo jack , Serial (RS-232)
- Memory Card Reader
- Yes (SD Card)
Software
- Software Included
- Microsoft Office (Trial)
- Shale black
- Security
- Impact-resistant, HDCP Compliant, Acer Aquafan
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- MIL-STD 810G, IP53
- SAR Value
- 0.96 W/kg (body), 0.96 W/kg (limb), 0.96 W/kg (head)
- Localization
- 1.98 kg
Sustainability Information
- TCO Certified
