Acer ED273wmidx 27" 1920x1080 4ms VGA DVI HDMI LED Monitor
Quicklinx: G0GKWS00 Mfr#: UM.HE3EE.011
A monitor that offers and exceptional curved form factor with a host of eye protecting technologies.
  • Curved to perfection
    Shaping your viewing experience with a curved form factor that delivers the incredible.
  • See the difference
    Cutting-edge tech features allow you to immerse yourself in extraordinary visuals.
  • Stay in the game
    The ED3 ensures you can enjoy all your favorite games with AMD FreeSync compatibility.
  • Silky smooth visuals
    With a rapid refresh rate, the Acer ED3 delivers ultra-smooth viewing with faster frame rendering and lower input lag.
  • High-speed response
    Keep pace with the action as the rapid response time reduces ghosting and smearing for clearer, more precise images.
  • Care for your vision
    Acer VisionCare incorporates several technologies to reduce eye strain and provide a more comfortable viewing experience.
Acer ED273 wmidx - LED monitor - curved - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/397325
Energy Class
Class F
Energy Consumption per Year
44 kWh
Power Consumption (On mode)
30 W
Curved Screen
Adaptive-Sync Technology
AMD FreeSync
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 100000000:1 (dynamic)
Response Time
4 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
White
61.28 cm x 16.82 cm x 46.59 cm
MPR II
Display Type
Energy Class
Class F
44 kWh
Diagonal Size
27"
Curved Screen
Yes (1800R)
AMD FreeSync
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Acer Adaptive Contrast Management (ACM), High Frame Rate Control (Hi-FRC), Mercury free, Acer VisionCare, Wide Viewing Angle, Acer BluelightShield technology
White
61.28 cm x 16.82 cm x 46.59 cm - with stand
Audio
Speakers - stereo
Output Power / Channel
3 Watt
VGA , DVI , HDMI , Audio line-out
Mechanical
Tilt
Tilt Angle
-5/+15
VESA Mounting Interface
100 x 100 mm
VESA interface support
1 x VGA cable
MPR II
Input Voltage
30 W
26 kWh/1000h
Power Consumption (Typical)
38 Watt
On / Off Switch
No
Dimensions & Weight Details
With stand - width: 61.28 cm - depth: 16.82 cm - height: 46.59 cm , Without stand - width: 61.28 cm - depth: 7.54 cm - height: 36.2 cm - weight: 3.72 kg
