Acer ED273A 27" 1920x1080 4ms DVI HDMI DP Curved Monitor
Quicklinx: DB04WS00 Mfr#: UM.HE3EE.A01
Acer ED273 - LED monitor - curved - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/397325
Energy Class
Class F
Energy Consumption per Year
44 kWh
Power Consumption (On mode)
26 W
Curved Screen
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 144 Hz
Brightness
250 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
4 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
AC 120/230 V
White
61.28 cm x 16.82 cm x 46.59 cm
United Kingdom
MPR II, DDC-2B, FCC Part 15, DDC, WEEE, EN 50564:2011, EN 50581:2012, Directive 1275/2008/EC, RoHS 2011/65/EU, EN 61000-3-3:2013, EN 55024:2010, ErP 2009/125/EC, EMC 2014/30/EU, LVD 2014/35/EU, EN 61000-3-2:2006+A2:2009 Class D, EN 55022:2010+AC:2011 Class B, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
Display Type
Energy Class
Class F
44 kWh
Diagonal Size
27"
Curved Screen
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Colour Temperature
9300K, 6500K, 5500K
HDCP, Overdrive technology, Acer Adaptive Contrast Management (ACM), High Frame Rate Control (Hi-FRC), game mode, ComfyView, Flicker-Less technology, Transition Minimised Differential Signaling (TMDS) technology, Blue Light Filter technology, 6-bit gamma, Wide Viewing Angle, Colour Temperature Selection, Movie Mode, Acer BluelightShield technology
White
61.28 cm x 16.82 cm x 46.59 cm - with stand
DisplayPort , DVI (HDCP) , HDMI , Audio line-out (mini-jack)
Mechanical
Tilt
Tilt Angle
-5/+15
LED indicator
1 x DisplayPort cable - DisplayPort to DisplayPort
United Kingdom
Input Voltage
AC 120/230 V
26 W
26 kWh/1000h
On / Off Switch
No
Dimensions & Weight Details
With stand - width: 61.28 cm - depth: 16.82 cm - height: 46.59 cm , Without stand - width: 61.28 cm - depth: 7.54 cm - height: 36.19 cm
